Items with no label
3340 Discussions
im trying to get the tare calibration to work. im using rs2_run_tare_calibration API with latest firmware and sdk;however, I always get calibration table which is set to NULL. I was wondering if anyone tried this API and whether im missing some steps here
ENoac1
std::future<const rs2_raw_data_buffer*> RealSenseDevice::startCalibration(const float ground_truth_mm, const void *jsonContent,int contentSize,rs2_update_progress_callback_ptr progressCallback, const int timeout) {
auto future = std::async(std::launch::async,[this,ground_truth_mm,jsonContent,contentSize,progressCallback,timeout]()->const rs2_raw_data_buffer*{
rs2_error* e = nullptr;
auto calibrationTable = rs2_run_tare_calibration(device.get().get(),20000,NULL,NULL,NULL,NULL,timeout*10,&e);
if(calibrationTable!= nullptr){
Log::Debug("SUCCESSSSSSSSSSSSSSSSSS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!") << Log::Endl;
} else
Log::Debug("FAILEDDDDDDDDDDDDDDDDDDDDDDDDDDDDD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!") << Log::Endl;
return calibrationTable;
return future;
MartyG
There is not much information available about tare calibration at present, so I recommend posting your question at the RealSense GitHub site so that a member of the RealSense developer team there can reply to it. You can post a question by visiting the link below and clicking the 'New Issue' button. Thanks four your patience!
https://github.com/IntelRealSense/librealsense/issues
ENoac1
thank you
