Items with no label
3341 Discussions
intrinsics, laser power python
ROhle
item 1) I cannot find python code to actively manage the laser power or to toggle the emitter. My attempts to translate the C++ code were (as expected:) no good.
item 2) Intrinsic Madness->
Not exactly sure what I am doing wrong here.
The following code is a lightly modified version posted by Intel in answer to a similar question.
I'm using a D435 with most recent updates across the board. Windows 8.1.
# Trying to get intrinsics (fx, etc.)
# First import the library
import pyrealsense2 as rs
pipe = rs.pipeline()
cfg = rs.config
cfg.enable_stream(rs.stream.color, 1920, 1080, rs.format. rgb8, 30)
cfg.enable_stream(rs.stream.infrared, 1,848,480,rs.format.y8,30)
cfg.enable_stream(rs.stream.infrared, 2,848,480,rs.format.y8,30)
cfg.enable_stream(rs.stream.depth,848,480,rs.format.z16,30)
prof = pipe.start(cfg)
ds = prof.get_stream(rs.stream.depth)
intr = ds.as_video_stream_profile().get_intrinsics()
print "depth"
print intr
s = prof.get_stream(rs.stream.infrared, 1)
print"IR1:"
print intr
s = prof.get_stream(rs.stream.infrared, 2)
print"IR2:"
print intr
ds = prof.get_stream(rs.stream.color)
print"color:"
print intr
And this gives the following:
depth
width: 848, height: 480, ppx: 424.713, ppy: 242.321, fx: 420.367, fy: 420.367, model: Brown Conrady
IR1:
IR2:
color:
width: 1920, height: 1080, ppx: 968.251, ppy: 536.9, fx: 1392.01, fy: 1392.87, model: Brown Conrady
Process finished with exit code 0
BUT:
If I change the order of getting the streams so that the color stream is looked at just after depth and before IR1 and IR2 I get:
depth
color:
IR1:
IR2:
item 3)
I convert from fx(pixel relative) to: fx(mm) = image_width/fx. For the Depth camera I get a reasonable answer(about 2), but for the color camera the answer is about 1.3... way far off.
Rich
MartyG
tem 1
The link below contains a sample script provided by Intel for controlling the laser power with Python.
https://github.com/IntelRealSense/librealsense/issues/1258 How to control the laser with python wrapper · Issue # 1258 · IntelRealSense/librealsense · GitHub
Item 2
RealSense user edgar.altamirano recently posted a script for getting intrinsics with Python.
jb455, whom I have linked into this conversation. JB, rjo's question is "I convert from fx(pixel relative) to fx(mm) = image_width/fx. For the Depth camera I get a reasonable answer(about 2), but for the color camera the answer is about 1.3... way far off."
jb455
Valued Contributor II
Item 2 looks like a bug. I'd suggest posting it on https://github.com/IntelRealSense/librealsense/issues Issues · IntelRealSense/librealsense · GitHub to see what the devs say.
Item 3... I don't really know about converting focal lengths from pixels to mm. The https://www.intel.com/content/dam/support/us/en/documents/emerging-technologies/intel-realsense-technology/Intel-RealSense-D400-Series-Datasheet.pdf datasheet has the specifications for the cameras, including their focal lengths in mm; but if you find the factory intrinsic parameters are wrong you can recalibrate yourself using OpenCV or similar then write to the camera using the https://downloadcenter.intel.com/download/27955/Intel-RealSense-D400-Series-Calibration-Tools-and-API calibration tools.
ROhle
Thanks guys. Have to wait til tonight to go through it all.
Rich
