Items with no label
3340 Discussions
is there any 3d scanning software for realsense D400??? I AM NOT A DEVELOPER
Zw2
hello everyone i have a D435 lately, but nothing i can do with it because I AM NOT A DEVELOPER!!!!!!
i am just a 3d animator and i wanna get *.3ds file with it.
is there any software for 3D scanning like itseez3d (it only support R200) or Easy3DScan(SR300)?
THX!!!sorry for my bad english
MartyG
Your English is good. As you want a .3ds format file, you are using 3DS Max modeling software, yes?
As far as I know, the new 400 Series cameras do not yet have support for 3D model creation from commercial software like ReconstructMe and ItSeez3D. It is possible to export a model file, though it takes some work.
First, you need to create a 3D point cloud and export it as a .ply file. the link below explains how to do this easily in the RealSense Viewer software.
When you have created your .ply file, you need to convert the point cloud to a mesh. this can be done with software called MeshLab.
http://www.meshlab.net/ MeshLab
There is a guide to doing this conversion with MeshLab.
https://www.andreasjakl.com/capturing-3d-point-cloud-intel-realsense-converting-mesh-meshlab/ https://www.andreasjakl.com/capturing-3d-point-cloud-intel-realsense-converting-mesh-meshlab/
There is also a YouTube video guide for using MeshLab to convert a .ply to an .obj, which should be easier to import into 3DS Max and turn into a .3ds file.
https://www.youtube.com/watch?v=nKLP1HpLjJo Converting .ply to .obj in Meshlab - YouTube
MartyG
Zw2
Thank you so much! i did it, but the result is not what i want cuz it's only one side
Is *.ply file just one view side?
Is there anyway to 3d scan an object all side, like scan a head?
MartyG
The camera can only capture the detail for the area that it can see. to create a 360 degree model, you need to take a series of captures and then combine them into a single model in 3D modeling software. You can do this either by putting the object on a rotating turntable (best for stable object scanning) or walking around the object whilst holding the camera. In the case of human face scanning, it may be easiest to have the camera in a static position and turn your body 360 degrees on the spot.
The easiest way to do 360 degree object scans with the old RealSense camera models (SR300 and R200) is Cappasity's 'Easy 3D Scan' software.
https://www.youtube.com/watch?v=VFgFB_IJdeQ Cappasity* Easy 3D Scan Using Intel® Realsense™ Technology | Intel Software - YouTube
https://www.youtube.com/watch?v=2AXo0IAWXxA Cappasity Easy 3D Scan. DSLR + 3D Camera mode - YouTube
ReconstructMe can do similar with the old RealSense camera models.
https://www.youtube.com/watch?v=eC9zuBkAKcE ReconstructMe - Turntable Scanner using Intel RealSense F200 - YouTube
A third body scanning option for the old camera models is ItSeez3D.
https://www.youtube.com/watch?v=6tqSKdztF5o itSeez3d tutorial on full body scanning with Intel® RealSense™ - YouTube
I do not know of a commercial solution that works with the new 400 Series cameras yet though. If any of the above packages are flexible enough in their implementation of RealSense to work with the new cameras too, it has not been reported back to us yet.
BPalm
There are a few software frames built around the SDK that are available now for those interested. I am not going To post links so you will need to do your due diligence looking. First couple that come to mind is Lipscan and Recfusion. I do have a list somewhere with a dozen or so compatible programs although they are mixed within a list along with Photogammetry and structured light programs that won't work with Intel. The main point is that they do exist and if you search long and hard you will find them. Some you must pay for and others are free. Metlab may be another that works with Raspberry Pi if you're going that route. We brought the list of programs in house so we can do comparitive analysis with the software were planning to develop over the next several months. Feel free to add upon the list for others interested.
MartyG
This is the latest information I have about 3D scanning solutions for the 400 Series:
