Items with no label
3340 Discussions
lens distortion in RealSenseSDK for Windows vs. librealsense *sigh*
SNoh4
Hello again,
I had a similar trouble to this thread ( ), so previously I tried to solve this issue by manual calibration.
I'm certain that I got more accurate calibration parameters, but it also makes weird 3D noise in point cloud.
I guess it came from the undistortion on depth image.
Anyway, at this moment, I am now trying to transfer my code from RSSDK for Windows (2016R3) to librealsense.
As expected (*sigh* ), I encountered another problem.
The problem now is the difference of lens distortion model.
In the previous RSSDK for Windows, the distortion model was radial/tangential distortion model, which is the same (?) with OpenCV.
Therefore, I just could utilize cv::undistort without a trouble.
Now I checked librealsense and just print out the calibration parameters in this new SDK, and I found that the distortion coefficients are different.
After few digging, I got it is Brown-Conrady distortion model.
However, I have no idea on this distortion model, and I cannot find the conversion between them, unfortunately.
So, here are my questions.
Is there any way to convert radial/tangential distortion model to Brown-Conrady model?
If it exists (I guess it should because librealsense just export different value without any touch), please provide us that information.
Thank you for your reading.
MartyG
Perhaps the Librealsense mode RS_DISTORTION_MODIFIED_BROWN_CONRADY would be useful to you. It is equal to Brown-Conrady, except that tangential distortion is applied to radially distorted points
MartyG
SNoh4
MartyG, hello again!
I just quickly modified code in C-Tutorials-3-pointcloud in librealsense SDK and checked it works, by using "struct rs_intrinsics".
By the way, why C++ API (rs::intrinsics) does not permit to modify "model" ?
It is quite awkward, but I'm now doing like this:
rs::intrinsics depth_intrin;
// depth_intrin.model(RS_DISTORTION_MODIFIED_BROWN_CONRADY); // what I want to do ...
auto modifyIntrinsicToModifiedBrownConrady = [](rs_intrinsics *intrin) {
intrin->model = RS_DISTORTION_MODIFIED_BROWN_CONRADY;
modifyIntrinsicToModifiedBrownConrady(&depth_intrin); // awkward, but anyway it works ...
MartyG
I'm very glad you got it working!
The only useful reference I could find about model() in regard to rs:intrinsics and distortion is this one, which explains the difference between the RealSense SDK and Librealsense distortion systems.
https://www.bountysource.com/issues/48438489-librealsense-vs-win-dcm-realsense-distortion-model Bountysource
