It's been roughly a week of research, trying different solutions to fix this problem but no dice.
Strange thing is that I am able to install the Intel driver in safe mode with no screen problems. The problem occurs only when booting into normal windows. The only exception for the screen working using normal boot is if I use the Microsoft Basic Display Adapter driver instead of the Intel HD Graphics 3000 driver.
Description of the problem (with Intel drivers installed) :
1. When I hit the login screen, I get some pixelation on the screen (not too much)
2. Randomly I get a black screen after logging in with only the cursor showing. The only thing I can do then is to wait and sometimes the screen comes back, or to use ctrl+alt+del.
3. When the screen does work, it is very pixelated with a lot of pink pixels as well as pixelated text.
Things I've tried:
1. System restore
2. Reinstalling/resetting the os and wiping out everything including all partitions
3. Installing all the Intel driver versions and ones from my laptops manufacturer website
4. I've tried chkdsk and sfc /scannow commands
5. Using DDU to clean out drivers before installing new drivers. Also used Easy Driver to find the best drivers to update with
6. Stopping windows from auto updating when installing drivers I want to test.
7. Cleaned out the laptop hardware and fans
8. Tried a second monitor using HDMI (problem persists on second monitor)
System information:
1- Asus x554l
2. Windows 10 ultimate edition 64 bit
3. Intel Hd graphics 3000
I'm at my wits end here and really need it to work asap. Hope someone can help fix this issue. Any other information needed I can supply. Thanks in advance!
Your processor and its Intel HD Graphics 3000 engine are not supported with Windows 10. You will be using the Microsoft Compatibility driver and support for all features is not guaranteed. Microsoft is no longer providing support for this driver, so any issues that you run into are not going to be fixed. Your choices are to put up with the issue or purchase a newer laptop.
Sorry, but this is the reality of the situation,
my proce is i5 i use windows 7 and not work for me any method for just hidding pixelat and glitch and why intel 3000 not comptapile with my proces ?
Your first message said Windows 10. All processors with Intel HD Graphics 3000 were discontinued in 2015 and the drivers are no longer being maintained. The last version of the drivers can be downloaded from here: https://downloadcenter.intel.com/download/24971/Intel-HD-Graphics-Driver-for-Windows-7-8-64-bit?product=81500. If this is the version that you are already using, then there is no remedy for your issue nor will there be.
You are running a now-discontinued version of Windows on a long discontinued processor. While you could upgrade to Windows 10 (for free using your Windows 7 license key), this doesn't make sense as the support for your processor's graphics is poor at best. Time to think about upgrading your hardware.
Sorry, but this too is the reality of the situation,
