Items with no label
3341 Discussions
need step by step for making Intel(r) camera CS431 work on Windows 7. And yes...first camera ever!
RRich40
don't ever download drivers .....so not that Good.. need help
RRich40
However you can still install this driver in Windows XP compatibility mode and check.
1. Right click on the driver setup file.
2. Go to properties.
3. Click on Compatibility mode.
4. Place a check mark the box in the box in front of “Run this program in compatibility mode for” and from the drop down menu choose Windows VisXP SP2.
5. Place a check mark on "Run as an Administrator" under privileges level and click on Apply and then Ok.
6. Now double click on the setup file to initiate the install.
I need step by step help
AlHill
This forum is for Intel NUCs. The CS431 has not had drivers for almost 20 years, and there are none for windows 7. And, Windows 7 is DEAD, as well as XP.
Doc
RRich40
A good tech would have said " hey, where did you find that old camera?" it is really old and you show go buy a new one as they are cheap......not worth trying to make work. AND>>>> No need to reply since this is a NUC forum. This old guy will just buy a new non- Intel camera ...of course!
AlHill
Glad to help.
Doc
