Items with no label
3340 Discussions
pointcloud capture with intel realsense f200 and pcl
sdas17
I want to use intel realsense f200 camera to capture pointclouds. I have seen ricks post at https://software.intel.com/en-us/articles/using-librealsense-and-pcl-to-create-point-cloud-data https://software.intel.com/en-us/articles/using-librealsense-and-pcl-to-create-point-cloud-data
His post assumes that the camera is r200 camera. I have only f200 camera. How can I use the provided code with an f200 camera. I know C++ and can do necessary changes to the code. I just need to know if its possible. Any hints on what functions/ headers I need to change will be helpful.
Hi Shome,
Thanks for your interest in the Intel RealSense Platform.
We would like to investigate a little bit more regarding your inquiry and as soon as we have useful information we'll let you know.
We'll appreciate your patience during the meantime.
-Yermi A.
Hi Shome,
Thanks for your patience. We have reviewed that article and it just mentions the R200 camera as you have mentioned, so it may or may not work using the F200 camera. However, we encourage you to attempt to run it with your F200 camera and share your results with the community since other users can also help you.
-Yermi A.
