Items with no label
3341 Discussions
probable error in static transforms
SMish7
I wanted to know the displacements between the various cameras on the euclid sensor and for getting this information i did a rostopic echo /tf_static on my euclid device's terminal. Although the transform data given for most frames seems correct, I think the transfrom data for the fisheye camera frame is wrong. I say so because camera_fisheye_frame is the child of camera_link frame and the camera_link frame coincides with the camera_rgb_frame. So, the camera_fisheye_frame must be about 8 to 9 cms toward the left of the camera_rgb frame but the information published by the /tf_static topic does not correspond to this. I will be grateful if someone can verify this can give me the correct displacement between the camera_rgb frame and the camera_fisheye_frame.
Meitav_K_Intel
Hi guys,
I printed out the /tf_static and the values for the fisheye transform that I got were around 2.7-3cm.
The distance between the fisheye and the left IR camera (to which everything is aligned) is 30mm, so the results are accurate.
I hope this makes more sense now.
Meitav
Intel Euclid Development Team
Hello SubMarIn,
Thanks for reaching out!
There are several known issues with Euclid's fisheye camera as you can see in https://communities.intel.com/docs/DOC-111978 https://communities.intel.com/docs/DOC-111978. However, I don't see any issue regarding a misplacing of the fisheye's frame.
Please let us investigate about this, we'll get back to you as soon as possible.
Pedro M.
SMish7
You can do a rostopic echo /tf_static and check it.
Hello SubMarIn,
We have analyzed the issue that you reported and it indeed looks like a bug. We have submitted it to the Euclid development team for further investigation.
We will update this thread when we have more information.
Pedro M.
Meitav_K_Intel
Hi guys,
Meitav
