Items with no label
3340 Discussions
scan3d.cs, when scan face, configuration not supported,why?
启王
SR300, scan head, body, object, all ok, only when choosing scan face, "configuration not supported" displayed.
MartyG
When using the 3DScan tool, you need to at least tick the 'Landmarks' option in the side panel before it will work. You can tick a combination of options (Solid, Texture, etc) but one of the ticked options must be Landmarks. For example, 'Landmarks + Solid' or 'Landmarks + Texture' or 'Landmarks + Solid + Texture'
MartyG
启王
you are right, thanks. could you please explain what is the meaning and function of "landmarks","marker"?
MartyG
Landmarks refers to the points on the human face that RealSense can track.
For an explanation about markers, please look at this documentation page. Thanks!
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?doc_scan_marker_tracking.html Intel® RealSense™ SDK 2016 R2 Documentation
启王
in object mode, when choosing solid or marker, the result is color image, when choosing texture or solid+texture, the result is white(looks like a statue),why?
jb455
Valued Contributor II
Texture mode saves the texture as a separate (higher resolution) file, so the colour information is no longer stored in the .obj file. The default three.js viewer can't handle texture files so you'll need to find a different application to view the object in (for example, 3D Builder which comes pre-installed with Windows 10 for some reason).
