Items with no label
3340 Discussions
segmentation fault after firmware update.
LPrad2
Required Info
Camera Model D420
Firmware Version 5.11.4.0
Operating System & Version Ubuntu16
Kernel Version (Linux Only) 4.15.0-50-generic
Platform PC
SDK Version { legacy 2.22.0 }
Issue Description
I installed via the process mentioned here: https://github.com/IntelRealSense/librealsense/blob/master/doc/distribution_linux.md.
On running realsense-viewer i kept getting messages to update the firmware to >5.10.
I followed the process mentioned here: https://www.intel.com/content/dam/support/us/en/documents/emerging-technologies/intel-realsense-technology/Linux-RealSense-D400-DFU-Guide.pdf
Here is the output of my firmware update process:
$ intel-realsense-dfu -b 002 -d 003 -f -i /home/hansolo/Downloads/IntelD420/dkms/D400_Series_Development_FW_5_11_4/Signed_Image_UVC_5_11_4_0.bin
  • Intel® RealSense™ DFU Tool v1.1.0-
Device busnum = 2
Device devnum = 3
FW file path = /home/hansolo/Downloads/IntelD420/dkms/D400_Series_Development_FW_5_11_4/Signed_Image_UVC_5_11_4_0.bin
FW Version of .bin File = 5.11.4.0
FW version on device = 5.9.2.0
MM FW Version = 255.255.255.255
FW update required...
Updating FW...
DFU FW version in file = 5.11.4.0
DFU_version = 60
DFU_isLocked = 0
FW_highestVersion = 0.0.0.0
FW_lastVersion = 0.0.0.0
Percentage done: 99
Running post download processes...
Post download processes done.
Done!
When I run realsense-viewer with the camera connected, the application closes with this as the output on the terminal:
10/06 17:43:14,205 WARNING [139687942130304] (synthetic-stream-gl.cpp:79) Initializing rendering, GLSL=1
10/06 17:43:14,205 WARNING [139687942130304] (synthetic-stream-gl.cpp:88) 0 GPU objects initialized
10/06 17:43:14,205 WARNING [139687942130304] (synthetic-stream-gl.cpp:131) Initializing processing, GLSL=1
10/06 17:43:14,287 WARNING [139687942130304] (synthetic-stream-gl.cpp:145) 0 GPU objects initialized
Segmentation fault (core dumped)
$intel-realsense-dfu -p, the output is:
Could not find device in opmode!
Device currently updating auxilliary modules, please try again later
$usb-devices
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 4 Spd=5000 MxCh= 0
D: Ver= 3.20 Cls=ef(misc ) Sub=02 Prot=01 MxPS= 9 #Cfgs= 1
P: Vendor=8086 ProdID=0af5 Rev=50.b4
S: Manufacturer=Intel(R) RealSense(TM) Invalid SKU
S: Product=Intel(R) RealSense(TM) Invalid SKU
S: SerialNumber=901313020388
C: #Ifs= 1 Cfg#= 1 Atr=c0 MxPwr=440mA
I: If#= 0 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
$dmesg --follow
[ 2658.584361] usb 2-1: new SuperSpeed USB device number 5 using xhci_hcd
[ 2658.604785] usb 2-1: config 1 interface 0 altsetting 0 has 0 endpoint descriptors, different from the interface descriptor's value: 2
[ 2658.604983] usb 2-1: New USB device found, idVendor=8086, idProduct=0af5
[ 2658.604988] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2658.604992] usb 2-1: Product: Intel(R) RealSense(TM) Invalid SKU
[ 2658.604996] usb 2-1: Manufacturer: Intel(R) RealSense(TM) Invalid SKU
[ 2658.605000] usb 2-1: SerialNumber: 901313020388
$lsusb
Bus 002 Device 005: ID 8086:0af5 Intel Corp.
udevadm monitor
monitor will print the received events for:
UDEV - the event which udev sends out after rule processing
KERNEL - the kernel uevent
KERNEL[2766.040629] add     /devices/pci0000:00/0000:00:14.0/usb2/2-1 (usb)
KERNEL[2766.040935] add     /devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.0 (usb)
UDEV [2766.044891] add     /devices/pci0000:00/0000:00:14.0/usb2/2-1 (usb)
UDEV [2767.052472] add     /devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.0 (usb)
$modinfo uvcvideo | grep ver
version:       1.1.2.realsense-1.3.5
description:   USB Video Class driver
srcversion:    3286F64D5B1431E64E8C37C
vermagic:      4.15.0-51-generic SMP mod_unload
Can you please help me regarding this issue. I tried setting the $ export LRS_LOG_LEVEL="" to all possible values but end up getting a 0 byte file.
MartyG
RealSense support moved to a new forum yesterday (June 10). It is still possible to post here but Intel support staff will not be answering. Please re-post your message on the new forum to receive support from the Intel support team (I do not work for Intel and your question is outside of my knowledge, unfortunately).
https://support.intelrealsense.com
LPrad2
Hi MartyG, thanks for the update. Will do that.
