Items with no label
3341 Discussions
to Detect the distance between the target and the camera,R200 or SR300 which is better
SYude
to detect the distance between the target and the camera,R200 or SR300 which is better?
help.
jb455
Valued Contributor II
It depends what sort of distance you want to measure. The R200 isn't much good below 50cm but can work to 3+ metres out, while the SR300 can go as close as 10-15cm but stops around 1.5-2m. The code for the two of them will be identical, so you could easily swap the cameras out depending on your subject.
Hi 11huamanlou,
Thank you for contacting us. I agree with jb455. You should choose a camera depending on the distance from the camera to the target. The SR300 is intended to be used in indoor applications that require a range from 20 to 120 cm.
You can see a thread that discusses this topic here: https://www.google.com/url?q=https://software.intel.com/en-us/forums/realsense/topic/684852&sa=D&sntz=1&usg=AFQjCNHGBIGlgh7RqebVA0jgQhxBc0PfHw https://software.intel.com/en-us/forums/realsense/topic/684852. Also, check the exact ranges here: https://www.google.com/url?q=https://software.intel.com/en-us/articles/intel-realsense-data-ranges&sa=D&sntz=1&usg=AFQjCNGAMO-Z9VV6mmw5GFTw_r7vjHaiWA https://software.intel.com/en-us/articles/intel-realsense-data-ranges
Let us know if this is what you were looking for.
Sergio
Hi 11huamanlou,
Do you still need assistance with this case? In case you do, please let us know.
-Sergio
