Items with no label
3340 Discussions
uv coordinate from get_texture_coordinates() is over 1
sshin9
I have testing pointcloud example in SDK 2.0 using D435.
// Wait for the next set of frames from the camera
rs2::frameset frames = pipe.wait_for_frames();
rs2::depth_frame depth_frame = frames.get_depth_frame();
// Generate the pointcloud and texture mappings
rs2::points points = this->pc.calculate(depth_frame);
rs2::video_frame color = frames.get_color_frame();
// Tell pointcloud object to map to this color frame
pc.map_to(color);
// save vertices and uvs
const rs2::vertex* rs_vertices = points.get_vertices();
const rs2::texture_coordinate* rs_tex_coords = points.get_texture_coordinates();
When I check the rs_tex_coords, u and v coordinate of some points is over 1.
I know uv coordinates have to be mapped to 0-1.
Why uv coordinate from rs2::points::get_texture_coordinate() is over 1 ?
Hi heavyman,
Thank you for your patience.
As can be seen in example.hpp, the coordinates from get_texture_coordinates() are used in the glTextCoord2fv function. The glTextCoord2fv function uses the terminology "s, t" instead of "u, v." Before this call, you will see these calls:
glTexParameterfv(GL_TEXTURE_2D, GL_TEXTURE_BORDER_COLOR, tex_border_color);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, 0x812F); // GL_CLAMP_TO_EDGE
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, 0x812F); // GL_CLAMP_TO_EDGE
I found a good discussion of what these settings do here: https://gamedev.stackexchange.com/questions/62548/what-does-changing-gl-texture-wrap-s-t-do https://gamedev.stackexchange.com/questions/62548/what-does-changing-gl-texture-wrap-s-t-do
It seems that the s, t coordinates can be greater than 1 when the texture repeats and must be clamped in order to stop at the edge, or border.
Does this help?
Alexandra
Hi heavyman,
Thank you for your interest in the RealSense D435 camera.
Let me look into it and I will get back to you later.
Alexandra
Hi heavyman,
Does this help?
Alexandra
Hi heavyman,
Was my answer helpful?
Do you have further questions?
Alexandra
