Can I use Media SDK on VM ?
ABoxe
I would like to set up an Azure instance that uses Media SDK to decode H264 video. Is this possible?
Thanks!
Mark_L_Intel1
Hi Aaron,
Media SDK uses hardware via graphic driver and I don't know how to enable it in VM. Does the following MS article help?
https://docs.microsoft.com/en-us/azure/virtual-desktop/configure-vm-gpu
We do support Docker:
https://github.com/Intel-Media-SDK/MediaSDK/wiki/Running-on-GPU-under-docker
Which part of the Azure are you using? I knew you can install tools like Media SDK in edge and communicate with Azure service.
Mark
Mark_L_Intel1
Hi Aaron,
Mark
Mendoza__Eduardo
Liu, Mark (Intel) wrote:
Hi Aaron,
Ludo club
Mark
Thanks friend
