Common Libraries for Intel Media SDK Sample c++17 support
bingol__evren
Are there any plans to bring the Intel sample code which does encode and decode up to speed with c++17
Mark_L_Intel1
Hi Evren,
Could you describe your use case?
I will fill up a feature request but a detailed description would help.
Mark
bingol__evren
Well Basically I am working on a project which uses some winrt10 functionality which needs to compile using c++17. It is a requirement by Microsoft. I want to use your sample_common as a lib in my project as it is a great helper.  But the headers in that sample_common.lib wont compile with c++17. There are some easy fixes like changing the auto pointers to unique pointers but there are some other stuff too. I start fixing it but I thought maybe Intel can update it as some of the c++ stuff in the common_sample is deprecated.
hope this helps.
Mark_L_Intel1
Thanks so much,
I have copied the description to the feature request and I will check when they are going to fix it.
Mark
