DirectShow Encoding failed
burkarth
Standard DirectShow Encoding failed.
3.0.554.34012 Beta4 at Win7.
What is going wrong?
Tracer 3.0 Log File:
GraphStudio-MP4_To_IntelH264Enc_Analyzer.log
Graph Screenshot:
GraphStudio
GraphStudio DirectShow graph details:
Filters
1. D:\\TestAnims\\MP4\\IMAG0031.MP4
File: D:\\TestAnims\\MP4\\IMAG0031.MP4
2. Microsoft DTV-DVD Audio Decoder
3. Microsoft DTV-DVD Video Decoder
4. Intel Media SDK AAC Encoder
5. Intel Media SDK H.264 Encoder
6. Intel Media SDK MP4 Muxer
7. File Sink
File: C:\\TEMP\\out.mp4
Connections
1. /(Video) -> [Microsoft DTV-DVD Video Decoder]/(Video Input)
Major: MEDIATYPE_Video
Subtype: {31435641-0000-0010-8000-00AA00389B71}
bFixedSizeSamples: FALSE
bTemporalCompression: FALSE
lSampleSize: 1
cbFormat: 190
Format: FORMAT_MPEG2_VIDEO
VIDEOINFOHEADER2:
rcSource: (0,0,0,0)
rcTarget: (0,0,0,0)
dwBitRate: 0
dwBitErrorRate: 0
AvgTimePerFrame: 333666
dwInterlaceFlags: 0
dwCopyProtectFlags: 0
dwPictAspectRatioX: 16
dwPictAspectRatioY: 9
dwControlFlags: 0
BITMAPINFOHEADER:
biSize: 40
biWidth: 1280
biHeight: 720
biPlanes: 1
biBitCount: 24
biCompression: 0x31637661
biSizeImage: 0
biXPelsPerMeter: 1
biYPelsPerMeter: 1
biClrUsed: 0
biClrImportant: 0
MPEG2VIDEOINFO:
dwStartTimeCode: 0
cbSequenceHeader: 58
dwProfile: 77
dwLevel: 40
Sequence Header:
00 32 27 4d 00 28 9a 62 80 a0 0b 77 fe 00 02 00
02 20 00 00 7d 20 00 1d 4c 1d 0c 00 3d 0a 00 01
12 a9 dd e5 c6 86 00 1e 85 00 00 89 54 ee f2 e1
f0 88 45 1e 00 04 28 ee 3c 80
2. /(Audio) -> [Microsoft DTV-DVD Audio Decoder]/(XForm In)
Major: MEDIATYPE_Audio
Subtype: {000000FF-0000-0010-8000-00AA00389B71}
lSampleSize: 1
cbFormat: 23
Format: FORMAT_WaveFormatEx
WAVEFORMATEX:
wFormatTag: 0x00ff (255)
nChannels: 2
nSamplesPerSec: 48000
nAvgBytesPerSec: 192000
nBlockAlign: 4
wBitsPersample: 16
cbSize: 5
Extradata:
11 90 00 00 00
3. [Microsoft DTV-DVD Audio Decoder]/(XFrom Out) -> [Intel Media SDK AAC Encoder]/(XForm In)
Subtype: MEDIASUBTYPE_PCM
bFixedSizeSamples: TRUE
lSampleSize: 1
cbFormat: 18
WAVEFORMATEX:
wFormatTag: 0x0001 (1)
nChannels: 2
nBlockAlign: 4
wBitsPersample: 16
cbSize: 0
4. [Microsoft DTV-DVD Video Decoder]/(Video Output 1) -> [Intel Media SDK H.264 Encoder]/(In)
Subtype: MEDIASUBTYPE_NV12
lSampleSize: 1382400
cbFormat: 1136
Format: FORMAT_VIDEOINFO2
VIDEOINFOHEADER2:
rcSource: (0,0,1280,720)
rcTarget: (0,0,1280,720)
dwBitRate: 331445218
dwBitErrorRate: 0
AvgTimePerFrame: 333667
dwInterlaceFlags: 129
dwCopyProtectFlags: 1
dwPictAspectRatioX: 1280
dwPictAspectRatioY: 720
dwControlFlags: 8321
BITMAPINFOHEADER:
biSize: 40
biWidth: 1280
biHeight: 720
biPlanes: 1
biBitCount: 12
biCompression: 0x3231564E
biSizeImage: 1382400
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
5. [Intel Media SDK AAC Encoder]/(XForm Out) -> [Intel Media SDK MP4 Muxer]/(Input 1)
lSampleSize: 1
cbFormat: 18
WAVEFORMATEX:
wFormatTag: 0x5473 (21619)
nChannels: 2
nAvgBytesPerSec: 16000
nBlockAlign: 1
wBitsPersample: 16
cbSize: 0
6. [Intel Media SDK H.264 Encoder]/(Out) -> [Intel Media SDK MP4 Muxer]/(Input 0)
Subtype: MEDIASUBTYPE_H264
bTemporalCompression: TRUE
lSampleSize: 1
cbFormat: 112
VIDEOINFOHEADER2:
dwBitRate: 4868000
dwBitErrorRate: 0
AvgTimePerFrame: 166833
dwInterlaceFlags: 0
dwPictAspectRatioX: 184320
dwPictAspectRatioY: 103680
dwControlFlags: 0
BITMAPINFOHEADER:
biSize: 40
biWidth: 1280
biHeight: 720
biPlanes: 1
biBitCount: 12
biCompression: 0x34363248
biXPelsPerMeter: 0
biYPelsPerMeter: 0
biClrUsed: 0
biClrImportant: 0
7. [Intel Media SDK MP4 Muxer]/(Output) -> [File Sink]/(in)
Major: MEDIATYPE_Stream
Subtype: GUID_NULL
lSampleSize: 1
cbFormat: 0
Format: GUID_NULL
Holger Burkarth
IDZ_A_Intel
Hi Holger,
Can you please provide some more info about your setup?
- Are you using Haali media splitter? I am able to reproduce similar issue using Haali, I get the error "Graph could not change state: At least one of the pins involved in the operation is already connected", is this also seen at your end?
- Would it be possible to share the MP4 file you are using so that we can reproduce your exact scenario?
Also, from the trace log I can see that HW acceleration is not used? What platform are you running your solution on?
Petter
burkarth
Hi Petter,
many thanks for your quick response.
Haali-Splitter was used in one case.
The "already connected" error is with MainConcept, but not with Haali on my system.
I have uploaded two media files for your tests.
Please read alldetails:
DirectShow Encoding via Intel H264 failed.pdf
Holger
IDZ_A_Intel
Hi Holger,
The URL to "IMAG0031.MP4" file is not working. Could you please upload again.
Regarding your platform configuration. The "Intel i7 860" is an older platform that does not support HW acceleration of encode. Also I see that you have a discrete card attached. If this is set to primary card, then HW acceleration via Media SDK will not work by default. You can either disconnect that card or follow the details in the Media SDK manual appendix to use Intel Processor Graphics via secondary monitor.
Also, make sure you use the latest Intel graphics driver for your platform.
Petter
burkarth
Hi Petter,
Both links are physically exists, but the pdf has not linked these files correctly.
I'm interesting on hw-acceleration and software encoding.
First, the software variant should work.
I hope that's possible.
Holger
IDZ_A_Intel
Hi Holger,
I still cannot get to "http://www.prodad.de/public/download/IMAG0031.MP4". Can you please make sure it's there?
Petter
burkarth
Hi Petter,
That's very strange. The link works on my site (Europe).
Both video files are attached this post.
Holger Burkarth
IDZ_A_Intel
Hi Holger,
sorry for the late reply on this post. We have been exploring your way of using the Media SDK sample filters and have the following comments and suggestions.
The DirectShowvideo encoder/decoder filters that are shipped with Media SDK are samples and due to limited resources we can only ensure support (and validate) for a small range of filters that may be connected with the sample filters. The "MS DTV-DVD Video Decoder" is unfortunately not part of our validation and therefore it's not surprising that you have encountered some issues.
We did perform some debugging using your setup and have assessed that supporting the DTV-DVD filter is not trivial, partially due to the way frame surfaces are handled.
We will continue to enhance our samples as part of the Media SDK product but we cannot commit to resolving this specific issue. We are also exploring how we can extend decoder samples to support other splitters than the binary reference splitters that is shipped with the SDK.
So based on this, may I suggest you instead explore using the SDK provided mp4 and mpeg splitters. Unfortunately this does not cover all types of content but it may partly satisfy your needs.
If you are adventurous you can explore making the required encoder filter changesyourself. After All, these are samples, you are free to modify in any way.
Petter
