Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3093 Discussions
GPU hangs when encoding simultaneously a HEVC (444-8 bits stream) and a H264 (420-8 bits stream) .
kmawassi
In Linux, running simultaneously a HEVC 444-8 bits encoding with another H264 420-8 bits encoding, causes a GPU hang.
i915 kernel messages:
i915 0000:00:02.0: [drm] Resetting vcs0 for preemption time out
i915 0000:00:02.0: [drm] sample_encode[142482] context reset due to GPU hang
i915 0000:00:02.0: [drm] GPU HANG: ecode 12:4:28ffff7d, in sample_encode [142482]
Steps to repro:
- Get an input AYUV raw file, and another input NV12 file raw.
- Repro command line using the sample_encode app:
sample_encode h265 -vaapi -hw -qsv-ff -async 4 -pp -g 60 -r 1 -f 60 -perf_opt 32 -n 20000 -vbr -b 5000 -ayuv -i ./AYUV_1080p.yuv -w 1920 -h 1080 -o /dev/null & sample_encode h264 -vaapi -hw -qsv-ff -async 4 -pp -g 60 -r 1 -f 60 -perf_opt 32 -n 20000 -vbr -b 5000 -nv12 -i ./NV12_1080p.yuv -w 1920 -h 1080 -o /dev/null
CPU model: 12th Gen Intel(R) Core(TM) i5-1235U (also reproduced on 13th Gen Inte(R) Core(TM) i5-1335u)
OS: Ubuntu 22.04 LTS
Kernel: 6.1.32-060132-generic
OneVPL runtime 2022Q3: 22.5.4
SreedeviK_Intel
Good day to you.
Thank you for posting in Intel communities.
We were able to reproduce your issue from our end on latest version of VPL (2023.4.0) and 12th Gen Intel(R) Core(TM) i9-12900K.
We could observe that while running AYUV, it is showing as unsupported as in the screenshot below.
We are checking with our internal team and will get back to you with an update shortly.
Sreedevi
