3092 Discussions
H264 Directshow filter - add fps conversion support
koby_s_
I'm trying to add fps conversion to the directshow H264 encoder filter.
To my understand, I need to set the struct members CEncVideoFilter::m_mfxParamsVPP.vpp.Out.FrameRateExtN and FrameRateExtD to the correct values.
Am I correct? Is there something else I need to do?
Also, how do I change the mediatype of the output pin? where is it implemented?
Thank you
Koby
Petter_L_Intel
Hi Koby, That is correct. vpp.In.FrameRateExtN/D and vpp.Out.FrameRateExtN/D will control frame rate conversion operation. For details and example on how to use frame rate conversion refer to the "sample_vpp" console sample part of the SDK. For mediatype control check out "filter_def.h" and "mfx_filter_register.h". Regards, Petter
koby_s_
Thank you Peter, I will check sample_cpp asap . Koby
