HEVC transcode benchmark
Ingvar_P_
I'd like to ask a question about  benchmarking process. On the IBC show in Amsterdam Intel demonstrated live transcode of 4K AVC source into HEVC with 90fps. When using sample_multi_transcode tool with -u 7 settings the best results I've got was ~56FPS transcoding 25Mbps 4k AVC into HEVC elementary stream. I ran this test on intel NUC NUC6I7KYK I7-6770HQ using linux version of the SDK. Could you please describe your benchmarking process, what samples and hardware did you use?
Ingvar
Anna_B_Intel
Hi Ingvar,
You're right, we demonstrated 4K AVC to HEVC transcoding with 90fps at IBC. I see one difference from what you described: we used HPE moonshot m710x powered by Intel Xeon 1585 v5 Server.
Best wishes,
Anna
