Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3093 Discussions
How to get transcode calc DecodingTimeStamp, TimeStamp?
parksh
Hello!
sample_multi_transcode(https://github.com/oneapi-src/oneVPL/blob/master/tools/legacy/sample_multi_transcode)
Debugging the sample code above PutBS() function call -> sts = m_pmfxSession->SyncOperation(pBitstreamEx->Syncp, GetSyncOpTimeout());
pBitstreamEx->Bitstream.Decode TimeStamp, pBitstreamEx->Bitstream.TimeStamp values ​​are returned
However, in software applications based on sample_multi_transcode, DecodingTimeStamp and TimeStamp values ​​are always returned as 0.
sts = m_pmfxDEC->Init(&m_mfxDecParams);
sts = m_pmfxVPP->Init(&m_mfxVppParams);
sts = m_pmfxENC->Init(&m_mfxEncParams);
&m_mfxDecParams, m_mfxVppParams, and m_mfxEncParams parameter values ​​all match
What processing should I do additionally to get DecodingTimeStamp and TimeStamp?
https://github.com/oneapi-src/oneVPL/blob/master/tools/legacy/sample_multi_transcode/src/pipeline_transcode.cpp
mfxStatus CTranscodingPipeline::PutBS() {
mfxStatus sts = MFX_ERR_NONE;
ExtendedBS* pBitstreamEx = m_BSPool.front();
MSDK_CHECK_POINTER(pBitstreamEx, MFX_ERR_NULL_PTR);
// get result coded stream, synchronize only if we still have sync point
if (pBitstreamEx->Syncp) {
m_ScalerConfig.Tracer->BeginEvent(SMTTracer::ThreadType::ENC,
TargetID,
SMTTracer::EventName::SYNC,
nullptr);
m_ScalerConfig.Tracer->EndEvent(SMTTracer::ThreadType::ENC,
TargetID,
nullptr);
m_ScalerConfig.Tracer->AfterEncodeSync();
HandlePossibleGpuHang(sts);
MSDK_CHECK_ERR_NONE_STATUS(sts, MFX_ERR_ABORTED, "Encode: SyncOperation failed");
if (m_pSurfaceUtilizationSynchronizer && m_MemoryModel != GENERAL_ALLOC) {
m_pSurfaceUtilizationSynchronizer->NotifyFreeCome();
m_nOutputFramesNum++;
msdk_stringstream ss;
ss << MSDK_STRING("[framenum: ") << m_nOutputFramesNum << MSDK_STRING(", ")
<< MSDK_STRING("frametype: ") << pBitstreamEx->Bitstream.FrameType << MSDK_STRING("] ")
<< MSDK_STRING("DTS: ") << pBitstreamEx->Bitstream.DecodeTimeStamp << MSDK_STRING(", ")
<< MSDK_STRING("PTS: ") << pBitstreamEx->Bitstream.TimeStamp
<< std::endl;
msdk_printf(MSDK_STRING("%s"), ss.str().c_str());
//--- Time measurements
if (statisticsWindowSize) {
outputStatistics.StopTimeMeasurementWithCheck();
outputStatistics.StartTimeMeasurement();
TargetID,
SMTTracer::EventName::WRITE_BS,
nullptr,
nullptr);
if (!m_ScalerConfig.ParallelEncodingRequired) {
sts = m_pBSProcessor->ProcessOutputBitstream(&pBitstreamEx->Bitstream);
else {
sts = m_pBSProcessor->ProcessOutputBitstream(&pBitstreamEx->Bitstream,
TargetID,
m_nOutputFramesNum);
TargetID,
nullptr,
nullptr);
MSDK_CHECK_STATUS(sts, "m_pBSProcessor->ProcessOutputBitstream failed");
UnPreEncAuxBuffer(pBitstreamEx->pCtrl);
pBitstreamEx->Bitstream.DataLength = 0;
pBitstreamEx->Bitstream.DataOffset = 0;
if (m_BSPool.size())
m_BSPool.pop_front();
m_pBSStore->Release(pBitstreamEx);
mfxU16 FrameTYpe = pBitstreamEx->Bitstream.FrameType;
return sts;
} //mfxStatus CTranscodingPipeline::PutBS()
CPU : i7-11700
OS : Windows 10 Pro for Workstations
API version : 2.3
oneVPL version : master version(2023.2.1)
libmfx64-gen.dll
- File Version : 11.21.6.24
- Product Version : 11.0.0.004
Thanks in advance for your reply.
AthiraM_Intel
Could you please share the sample reproducer code which has your modifications and the exact steps you followed?
parksh
I'm sorry
The timestamp initalization part was missing in the code I modified.
By adding the code below, I was able to get the TimeStamp value returned.
FileBitstreamProcessor::FileBitstreamProcessor() {
    MSDK_ZERO_MEMORY(m_Bitstream);
    ===> m_Bitstream.TimeStamp = (mfxU64)-1;
} // FileBitstreamProcessor::FileBitstreamProcessor()
AthiraM_Intel
Glad to know that your issue is resolved. Thanks for sharing the solution with us. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
