3087 Discussions
How to set "I Frame Interval" in Media SDK H264 Encoder Dshow filter?
lonely_hearts_club
I have set
m_EncoderParams.ps_control.GopPicSize = 50;
m_EncoderParams.ps_control.GopRefDist = 0;
But the I Frame Interval was still 256.
It seems that no matter what value I set to GopPicSize,the I Frame Interval remains constant(=256).
What went wrong?
My parameters setting was like this:
void CH264EncVideoFilter::SetDefaultParams(void)
m_EncoderParams.level_idc = Params::LL_AUTOSELECT;
m_EncoderParams.profile_idc = Params::PF_AUTOSELECT;
m_EncoderParams.pc_control = Params::PC_FRAME;
m_EncoderParams.ps_control.NumSlice = 0; // autoselect
m_EncoderParams.rc_control.rc_method = IConfigureVideoEncoder::Params::RCControl::RC_VBR;
m_EncoderParams.rc_control.bitrate = 0;
m_EncoderParams.target_usage = MFX_TARGETUSAGE_BALANCED;
m_EncoderParams.preset = CodecPreset::PRESET_USER_DEFINED;
m_EncoderParams.frame_control.width = 0;
m_EncoderParams.frame_control.height = 0;
later,I found out that
CH264EncVideoFilter::CH264EncVideoFilter(TCHAR* tszName, LPUNKNOWN punk, HRESULT* phr) :
CEncVideoFilter(tszName, punk, FILTER_GUID, phr)
m_bstrFilterName = FILTER_NAME;
m_mfxParamsVideo.mfx.CodecId = MFX_CODEC_AVC;
//fill m_EncoderParams with default values
SetDefaultParams();
// Fill m_EncoderParams with values from registry if available,
// otherwise write current m_EncoderParams values to registry
// ReadParamsFromRegistry();
CopyEncoderToMFXParams(&m_EncoderParams, &m_mfxParamsVideo);
AlignFrameSizes(&m_mfxParamsVPP.vpp.Out, (mfxU16)m_EncoderParams.frame_control.width, (mfxU16)m_EncoderParams.frame_control.height);
ReadParamsFromRegistry() function Fill m_EncoderParams with values from registry, so I just simply cancled this statement, GraphEdit says "This graph can't play(return code:0x80004005)
(Version 3.0.774.38156)
-Patrick
Petter_L_Intel
Hi again,
let me add some clarification to avoid potential confusion. The suggestion I gave works for the case when preset is used (such as PRESET_BALANCED).
But if you do not want to use a preset then you can set preset to PRESET_USER_DEFINED and in that case the parameter values you set will be applied even without the suggested code change.
Petter
lonely_hearts_club
I finally found out that RCControl should set to CBR. Does it mean that I cannot use the VBR capability if i want to set I frame interval myself?
Petter_L_Intel
The Media SDK DShow samples are unfortunately not perfectly suited for direct manipulation of parameters. Feel free to modify the sample code to fit your needs.
But to quickly get around the issue I suggest you remove the "CodecPreset::VParamsFromPreset()" call located at the end of the function "CopyEncoderToMFXParams" in "mfx_video_enc_filter_utils.cpp". This small change will let you set the parameter values using the SetParam() function.
Petter
lonely_hearts_club
Thanks for you suggestion!!
Petter_L_Intel
Hi again,
Petter
