Installation of Media studio on CentOS 7 fails
hendrik_f_
I am trying to use ffmpeg with h264_qsv. I am following this manual:
http://www.intel.ua/content/dam/www/public/emea/xe/en/documents/white-papers/quicksync-video-ffmpeg-install-valid.pdf
When installing intel-linux-media-16.4.4-47109.el7.x86_64.rpm though, I get an error:
Loaded plugins: changelog, fastestmirror
Examining intel-linux-media-16.4.4-47109.el7.x86_64.rpm: intel-linux-media-16.4.4-47109.el7.x86_64
Marking intel-linux-media-16.4.4-47109.el7.x86_64.rpm to be installed
Examining intel-linux-media-devel-16.4.4-47109.el7.x86_64.rpm: intel-linux-media-devel-16.4.4-47109.el7.x86_64
Marking intel-linux-media-devel-16.4.4-47109.el7.x86_64.rpm to be installed
Resolving Dependencies
--> Running transaction check
---> Package intel-linux-media.x86_64 0:16.4.4-47109.el7 will be installed
--> Processing Dependency: libdrm = 2.4.56-47109.el7 for package: intel-linux-media-16.4.4-47109.el7.x86_64
Rockstor-Testing        | 2.9 kB  00:00:00
rockstor        | 2.9 kB  00:00:00
Loading mirror speeds from cached hostfile
 * base: centosmirror.netcup.net
 * epel: mirror.nl.leaseweb.net
 * extras: centosmirror.netcup.net
 * updates: centosmirror.netcup.net
---> Package intel-linux-media-devel.x86_64 0:16.4.4-47109.el7 will be installed
--> Finished Dependency Resolution
Error: Package: intel-linux-media-16.4.4-47109.el7.x86_64 (/intel-linux-media-16.4.4-47109.el7.x86_64)
           Requires: libdrm = 2.4.56-47109.el7
           Installed: libdrm-2.4.60-3.el7.x86_64 (@anaconda/3)
               libdrm = 2.4.60-3.el7
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
Here I am stuck. I don't know how to install the cherry-picked version of libdrm.
Can anyone help on this?
About my system:
cat /proc/cpuinfo | grep -i intel
vendor_id       : GenuineIntel
model name      : Intel(R) Pentium(R) CPU G3220 @ 3.00GHz
[root@homeserver CentOS]# lsmod | grep i915
i915                 1212416  2
i2c_algo_bit           16384  1 i915
drm_kms_helper        135168  1 i915
drm                   356352  3 i915,drm_kms_helper
video                  40960  1 i915
Hendrik
Jeffrey_M_Intel1
Hi Hendrik,
From the release notes for this release:
Intel® Celeron®, Intel® Pentium® and Intel® Atom™ processors are not supported
So, no guarantees that Media SDK will install for this processor.  However, if you want to keep trying the install_sdk_UMD_CentOS.sh script and the Getting Started Guide should help with the steps necessary.  Part of the install procedure will add a customized libdrm to the system.
