3088 Discussions
MFX_HANDLE_VA_DISPLAY mfxHandleType even not exist !!!!!!!!
zheng_s_
I download the Media sdk Linux version and install on my linux machine.I try to build my first decode-piple code. I just copy the orignial source code with my wrapper. here is the orignal code from sample_decode/pipeline_decode.cpp
sts = m_mfxSession.SetHandle(static_cast<mfxHandleType>(MFX_HANDLE_VA_DISPLAY), va_dpy);
but compiler compalin the MFX_HANDLE_VA_DISPLAY not defined. Then I check the header file definition in /opt/intel/mediasdk/include/mfxstructures.h
typedef enum {
    MFX_HANDLE_DIRECT3D_DEVICE_MANAGER9         =1,      /* IDirect3DDeviceManager9      */
    MFX_HANDLE_D3D9_DEVICE_MANAGER              = MFX_HANDLE_DIRECT3D_DEVICE_MANAGER9,
    MFX_HANDLE_RESERVED1                        = 2,
    MFX_HANDLE_D3D11_DEVICE                     = 3,
    MFX_HANDLE_RESERVED2                        = 4,
    MFX_HANDLE_RESERVED3                        = 5
} mfxHandleType;
The MFX_HANDLE_VA_DISPLAY even dont exist !!!! And looks it supports Windows DirectX Only!!!!!!
here i
Jeffrey_M_Intel1
While it is true that the mfxHandleType enum in mfxstructures.h shows its Windows roots, you can find MFX_HANDLE_VA_DISPLAY in mfxlinux.h.
