MFXVideoENCODE_EncodeFrameAsync constantly returns MFX_WRN_DEVICE_BUSY
Oleg_F_
I'm using MSS 2015R3 (I also upgraded to R4, but the issue still exists)
CentOS 7
My scenario is as following:
-H.264 decoder (720p 30fps high profile) => VPP composition(only one input) => H.264 encoder (720p 30fps high profile)
-each component uses its own session, but all 3 sessions are joined
After about 20 seconds of successfull work, H.264 encoder (MFXVideoENCODE_EncodeFrameAsync) begins returning MFX_WRN_DEVICE_BUSY and it returns it constantly, i.e. after sleep it continues to return MFX_WRN_DEVICE_BUSY. The only way to get out of it is to restart the process, then everything repeats.
*The interesting thing is that the decoder and the VPP continue to work normally
*Another interesting thing is that the last time encoder works properly, its MFXVideoCORE_SyncOperation returns MFX_ERR_UNDEFINED_BEHAVIOR and the next time after that encoder's MFXVideoENCODE_EncodeFrameAsync begins returning MFX_WRN_DEVICE_BUSY.
Please help me with this issue
It is pretty urgent
Oleg
Oleg_F_
And one more detail: this issue is not reproduced if I change encoder high profile to baseline profile.
Shaojuan_Z_Intel
Are you using the samples in MSS? If you modified the samples, could you give us the reproducer code so that we can take a look at the issue? Another approach, will you be able to reproduce the issue with sample_multi_transcode ?
