Media DirectShow Sample not working
Kevin_A_
I'm compiling up the DirectShow H.264 Encoder, trying to get it to work.  However i cannot get it to connect to any source filters.
it's failing on this line
mfx_video_enc_filter.cpp:944 sts = m_pEncoder->m_pmfxVPP->QueryIOSurf(&m_mfxParamsVPP, mfxVppRequest);
sts is MFX_ERR_INVALID_VIDEO_PARAM
The source filter works on my own x264 filter, as wells as elecard's encoder, Main concepts, and LEAD's h.264 encoder.  The source outputs 1080p, RGB32, 25fps.
I'm just starting to get into QuickSync programing, and would appreciate any help.
Kevin_A_
Processor Type:Intel(R) Core(TM) i5-5250U CPU @ 1.60GHz
Driver Version:Intel(R) HD Graphics 6000                    10.18.14.4156
Operating System:Microsoft Windows 8.1 Pro
Media SDK System Analyzer:
        Version Target  Supported       Dec     Enc
        1.0     HW      Yes             X       X
        1.0     SW      Yes             X       X
        1.1     HW      Yes             X       X
        1.1     SW      Yes             X       X
        1.3     HW      Yes             X       X
        1.3     SW      Yes             X       X
        1.4     HW      Yes             X       X
        1.4     SW      Yes             X       X
        1.5     HW      Yes             X       X
        1.5     SW      Yes             X       X
        1.6     HW      Yes             X       X
        1.6     SW      Yes             X       X
        1.7     HW      Yes             X       X
        1.7     SW      Yes             X       X
        1.8     HW      Yes             X       X
        1.8     SW      Yes             X       X
What I've discovered is if i set the resolution to a power of 32, eg 1920*1088  sometimes it works.
Shaojuan_Z_Intel
Hi Kevin, thanks for your updates. Your system is based on Broadwell architecture. Currently Media SDK doesn't support Broadwell. Please refer to this thread (http://software.intel.com/en-us/forums/topic/545094) for related information. Thanks.
Kevin_A_
It also does not work on
Processor Type:Intel(R) Core(TM) i5-4250U CPU @ 1.30GHz   1.90GHz
Anthony_P_Intel
I noticed you mentioned that you are providing "1080p, RGB32, 25fps" input.
It has been a while since I looked at the older Direct Show sample encoder, however I believe it only accepts NV12 (YUV 420) input.
