Memory lock failure.
VASILY_V_
Hello!
I've tried to write my own application based on Media SDK API and encounter a error when I've tried to lock surface when read/write video surfaces:
Also such error I've encounter with simple_decode_vmem util, and I can't figure out what's wrong.
Memory lock failure. src/simple_decode_vmem.cpp
How can I solve this issue?
Thank you!
Bjoern_B_Intel
Hi Vasily,
can you describe in more detail what you are seeing and share your code so we can look into. Please also share your platform details and configuration.
Bjoern
VASILY_V_
Bjoern Bruecher (Intel) wrote:
Hi Vasily,
Bjoern
Hi, Bjoern!
Thank you for your answer. I've tried many times but actually just use one of the samples from your MediaSDK and it works fine.:)
About decoding with sample - can't reproduce a bug for now. Return back for this thread when it's appear again.
