Multi-VPP crash issue
abel_z_
Hello:
       I'm using intel hw to encode h264 video recently, and i found that the program will always crash. after serval week's debug, i found it's caused by VPP, and i wrote a small test program,  only use VPP, after serval hours or 1 or 2days, it will crash in libmfx32.dll. my use case is:
       1. malloc memory for input YUV
       2. read YUV data.
       3. malloc memory2.
       4. copy YUV from memory to memory2.
       5. malloc memory3 for output YUV.
       6. attach memory2 and memory 3 to input and output surface.
       7. call RunFrameVPPAsync
       8. call SyncOperation
       9. free all the memory.(in my real environment, i need always malloc and free memory like this)
       10. loop it forever.
        i have upload all the test solution, for input YUV, i use 1920*1088(for multiple of 32)&NV12, so you can use any YUV with this format to reproduce it.
         my system information:
         SDK: Media SDK 2014 for Clients & Media SDK 2014 R2 for Clients
         Driver version: 10.18.10.3621
         CPU: Intel(R) Xeon(R) CPU E3-1245 V3
         GPU: Intel(R) HD Graphics P4600/4700
         System: Windows 8.1
         Analyzer output:420769
The following versions of Media SDK API are supported by platform/driver:
    Version    Target    Supported    Dec    Enc
    1.0    HW    Yes        X    X    [Adapter 1]
    1.0    SW    No
    1.1    HW    Yes        X    X    [Adapter 1]
    1.1    SW    No
    1.3    HW    Yes        X    X    [Adapter 1]
    1.3    SW    No
    1.4    HW    Yes        X    X    [Adapter 1]
    1.4    SW    No
    1.5    HW    Yes        X    X    [Adapter 1]
    1.5    SW    No
    1.6    HW    Yes        X    X    [Adapter 1]
    1.6    SW    No
    1.7    HW    Yes        X    X    [Adapter 1]
    1.7    SW    No
    1.8    HW    Yes        X    X    [Adapter 1]
    1.8    SW    No
Graphics Devices:
    Name                                         Version             State
    Intel(R) HD Graphics P4600/P4700             10.18.10.3621       08
    Matrox G200eR (WDDM 1.2)                     4.0.1.4             Active
System info:
    CPU:    Intel(R) Xeon(R) CPU E3-1245 v3 @ 3.40GHz
    OS:    Microsoft Windows 8.1
    Arch:    64
Installed Media SDK packages (be patient...processing takes some time):
Sravanthi_K_Intel
Hello there -
"ncode h264 video recently, and i found that the program will always crash" --> What encode application did you use? Did you use sample_encode from samples or simple_encode from the tutorials?
"caused by VPP"--> Can you please run the tutorial applications such as simple_4_vpp_resize_denoise and let us know if you are seeing similar behavior (VPP crashing I mean).
In general, we highly recommend you use our samples and tutorials applications as starting points. For simple encode test, you could use simple_3_encode tutorial or its variants, for simple vpp operations test, the sample I mentioned above. If you want to test multiple encodes and vpp, you can use the sample_encode and sample_vpp samples.
Let me know if you can reproduce the issue you are seeing with the samples/tutorials I mentioned above - that would be greatly helpful.
