Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3090 Discussions
Not able to detect GstVA encoders using gst-inspect
npawar
I have built Gstreamer 1.24 on below platform.
GPU: Meteor Lake-P [Intel Arc Graphics]
CPU: Intel® Core™ Ultra 7 Processor 155HL
Kernel: Linux 6.7.12+bpo-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.7.12-1~bpo12+1 (2024-05-06) x86_64 GNU/Linux
Meson build command:
Explain
run meson setup . .. \
        --buildtype release --unity off --strip \
        --default-library shared \
        --wrap-mode=nofallback \
        -Dorc-source=system \
	-Dgpl=enabled \
        -Drs=enabled \
	-Dcpp_args="-std=c++20" \
        -Dexamples=disabled -Dtests=enabled -Dgtk_doc=disabled \
        -Dpackage-origin="$Gxx" $OPTS "
OS Details:
  • OS: Ubuntu-22.04
  • libva version: 2.17
  • libva-utils version: 2.17
The build was successful. Additionally I checked and the Video card is present under /dev/dri . I set LIBVA_DRIVER_NAME=iHD and the appropriate path of LIBVA_DRIVERS_PATH However, when I do gst-inspect-1.0 va I can only see decoders present and only two encoders. I am specifically looking for the vapostproc element and vah264enc encoders. Is there any step or a process I’m missing. Please suggest.
JeanetteC_Intel
Hello npawar,
We'll check on this query and we will post an update once it's available.
Jeanette C.
JeanetteC_Intel
Hello npawar,
I have reviewed your concern and wanted to let you know that we have a dedicated forum for this type of issue, where you can get faster answers. I am moving this to the "Intel® Video Processing Library, Intel Media SDK" Forum for you.
Sincerely,
JeanetteC.
Intel Customer Support Technician
