QuickSync failed to decode H264 using YV12 input
song_l_
Hi.
the MFXVideoENCODE_Init function failed when FourCC set to  MFX_FOURCC_YV12;
Is that mean QuickSync doesn't support YV12 input or something I missed?
The source is:
m_mfxEncParams.mfx.FrameInfo.FourCC = MFX_FOURCC_NV12; //OK
//m_mfxEncParams.mfx.FrameInfo.FourCC = MFX_FOURCC_YV12; //NG
m_mfxEncParams.mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420;
m_mfxEncParams.mfx.FrameInfo.PicStruct = MFX_PICSTRUCT_PROGRESSIVE;
status = MFXVideoENCODE_Init(session, &m_mfxEncParams);
The enviroment is;
  Intel(R) HD Graphics 4600                    10.18.15.4256       Active
  Intel(R) Core(TM) i7-4710HQ CPU @ 2.50GHz
   Intel(R) Media SDK 2016
What should I  do to encode a YV12 source to H264.
Jeffrey_M_Intel1
For this scenario you will want to do VPP colorspace conversion first.  For a starting point you can use simple_6_encode_vmem_vpp_preproc from the tutorials package.  This shows RGB4->NV12 but it should be straightforward to switch to YV12 input.  For h264 the encoder needs NV12 inputs.
Regards, Jeff
