Re encode I-Frame
Oh_i_
Hi all,
I'm using the H.264 video encoder with the following parameters:
CodecId = MFX_CODEC_AVC;
TargetUsage = MFX_TARGETUSAGE_BALANCED;
TargetKbps = 10000;
RateControlMethod = MFX_RATECONTROL_VBR;
if(RateControlMethod == MFX_RATECONTROL_VBR)
MAXKbps = 11000;
InitialDelayInKB = 10000;
if(RateControlMethod == MFX_RATECONTROL_AVBR)
Accuracy = 10;
Convergence = 10;
FramRateExtN = 25;
FramRateExtD = 1;
FourCC = MFX_FOURCC_NV12;
ChromaFromat = MFX_CHROMAFORMAT_YUV420;
PicStruct = MFX_PICSTRUCT_PROGRESSIVE;
Width = 192;
Height = 1080;
GopPicSize = 25;
GopRefDist = 1;
IdrInterval = 0;
CodecProfile = MFX_PROFILE_AVC_MAIN;
CodecLevel = 50;
IOPattern = MFX_IOPATTERN_INSYSTEM_MEMORY;
GopOptFlag = MFX_GOP_STRICT|MFX_GOP_CLOSED;
now I'm trying to re-encode I-frame, with the same input frame using the following:
m_encCtrl.FrameType = MFX_FRAMETYPE_I|MFX_FRAMETYPE_IDR
I expected the output will be the same, but! it is not! sometimes bigger, sometimes smaller, no consistency!
To make it clear:
1. Grab fram #F
2. Encode #F frame as I-frame (received stream with size of X)
3. Re-encode #F frame forcing I-frame (received stream with size of Y ???, should be X!!)
anyone?
Anthony_P_Intel
If I'm understanding your question correctly, i believe your answer lies in the method that Variable Bit Rate is maintained (AVBR or VBR encoding).  When encoder is setup to attempt an target bitrate (in your case 10 Mbits) and a GopPicSize of 25, indicating expected I frame frequency, then encoder can expect to spend one amount of bits on first (IDR) frame assuming the rest of the bits are spread on remaining frames (expecting B and P frames to require less bits to maintain quality), but when new/forced I Frame is requested early, the number of bits already used in the sequence have to be taken into account if 10Mbps target bitrate is to be maintained.
