Running OpenCL kernel (s) on CPU and GPU
Kapil_D_
I am posting my queries in "media" forum because I think they are related to the OpenCL driver. Please let me know if I should post it to some other forum as well.
I have installed intel media server studio essential 2015 R5 took kit. I have CentOS 7.1 running on Intel i7-4790K processor with HD4600 graphics. I want to confirm/ask following points related to running OpenCL programs with the new OpenCL Driver:
1) Although the website (https://software.intel.com/en-us/articles/opencl-drivers , 3rd option) says that the OpenCL driver on Linux OS supports only GPU, I am able to run the programs on both CPU and GPU by using CL_DEVICE_TYPE_{GPU/CPU} options. I am wondering if there is any limitation that I should be aware of while running a program on CPU. Please confirm.
2) Is it possible to execute multiple kernels at the same time on GPU? More specifically, I would like to know about the scheduling behavior in following cases:
(a) When multiple kernels (with no dependencies among them) are launched from an application through multiple command-queues: Do these kernels run concurrently, say when a particular kernel does not use all available cores of GPU? I know that there are four time stamps in a kernel execution: enqueue, submit, start, end. Can multiple kernels have an overlap between start and end? I think Device fission is one way of dividing the number of cores in to different groups, but I am wondering if the GPU hardware has an internal mechanism to run multiple kernels without Device fission?
(b) When multiple kernels are launched from DIFFERENT applications: Here, different kernels belong to different programs. How does the OpenCL driver schedule kernels in this case? Can multiple kernels "run" concurrently?
Kapil
Shaojuan_Z_Intel
Hi Kapil,
Could you post your questions in the OpenCL forum here http://software.intel.com/en-us/forums/opencl? I think you will get more information there. Thanks!
Kapil_D_
Thanks Shaojuan!
Based on your suggestion, I posted it on "OpenCL" forum as well.
-Kapil
