Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Why am I getting frames with incorrect timestamps?
parksh
Hello?
sample_multi_transcode(https://github.com/oneapi-src/oneVPL/blob/master/tools/legacy/sample_multi_transcode)
sample_multi_transcode -i::h264 INPUT.h264 -o::h264 OUTPUT.h264 -hw -FRC::INTERP -f 30.00 -w 320 -h 180 -FRC::INTERP -gop_size 150 -dist 1
CPU : i7-11700
OS : Windows 10 Pro for Workstations
API version : 2.3
oneVPL version : master version(2023.2.1)
libmfx64-gen.dll
- File Version : 11.21.6.24
- Product Version : 11.0.0.004
Thanks in advance for your reply.
AthiraM_Intel
We assume that you have modified the code. Could you please share the sample reproducer code which has your modifications and the exact steps you followed?
parksh
This is the sample code I tested.
run sample_multi_transcode.exe
sample_multi_transcode.exe -i::h264 INPUT.h264 -o::h264 OUTPUT.h264 -hw -FRC::INTERP -f 30.00 -w 320 -h 180 -FRC::INTERP -gop_size 150 -dist 1
AthiraM_Intel
Thank you for sharing the details. We are checking on this internally. We will get back to you soon with an update.
AthiraM_Intel
We are getting dependency issues while building the sample which you shared.
Could you please share the reproducer code with all the dependencies.
Also share the steps to build the sample.
parksh
https://github.com/oneapi-src/oneVPL/tree/master/tools/legacy/sample_common/include/mfx_samples_config.h
https://github.com/oneapi-src/oneVPL/tree/master/api/vpl/mfxdefs.h
The oneVPL github master version installation path was dependenced.
Not the modified source I provided
Even if you debug with the oneVPL github master version, if you test with the input video sample I provided,
(https://github.com/oneapi-src/oneVPL/blob/master/tools/legacy/sample_multi_transcode/src/pipeline_transcode.cpp#L2092)
In this part, the bitstream DecodingTimeStamp, TimeStamp -1 will be returned.
I wonder how I can understand why the bitstream that returns as -1 exists.
thanks
AthiraM_Intel
We are checking on this internally. We will get back to you with an update.
