install_sdk_UMD_CentOS.sh errors
rshal2
New Contributor II
I am following the exact instruction for install of media sdk server, but I get the below errors.
Can anyone please assist ?
[root@localhost CentOS]#
[root@localhost CentOS]# ./install_sdk_UMD_CentOS.sh
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
 * base: centos.syn.co.il
 * extras: centos.syn.co.il
 * updates: centos.syn.co.il
Maybe run: yum groups mark install (see man yum)
No packages in any requested group available to install or update
Package kernel-headers-3.10.0-327.3.1.el7.x86_64 already installed and latest version
Package kernel-devel-3.10.0-327.3.1.el7.x86_64 already installed and latest version
Nothing to do
Package bison-2.7-4.el7.x86_64 already installed and latest version
Package ncurses-devel-5.9-13.20130511.el7.x86_64 already installed and latest version
Package hmaccalc-0.9.13-4.el7.x86_64 already installed and latest version
Package zlib-devel-1.2.7-15.el7.x86_64 already installed and latest version
Package binutils-devel-2.23.52.0.1-55.el7.x86_64 already installed and latest version
Package elfutils-libelf-devel-0.163-3.el7.x86_64 already installed and latest version
Package rpm-build-4.11.3-17.el7.x86_64 already installed and latest version
Package redhat-rpm-config-9.1.0-68.el7.centos.noarch already installed and latest version
Package asciidoc-8.6.8-5.el7.noarch already installed and latest version
Package perl-ExtUtils-Embed-1.30-286.el7.noarch already installed and latest version
Package pesign-0.109-9.el7.x86_64 already installed and latest version
Package xmlto-0.0.25-7.el7.x86_64 already installed and latest version
Package audit-libs-devel-2.4.1-5.el7.x86_64 already installed and latest version
Package elfutils-devel-0.163-3.el7.x86_64 already installed and latest version
Package newt-devel-0.52.15-4.el7.x86_64 already installed and latest version
Package numactl-devel-2.0.9-5.el7_1.x86_64 already installed and latest version
Package pciutils-devel-3.2.1-4.el7.x86_64 already installed and latest version
Package python-devel-2.7.5-34.el7.x86_64 already installed and latest version
Nothing to do
Preparing...                          ################################# [100%]
    package libdrm-2.4.56-39163.el7.x86_64 is already installed
+++ Intstall complete, adding HotFixes
intel-linux-media-patches-39163/
intel-linux-media-patches-39163/libdispatch_trace.a
intel-linux-media-patches-39163/libdispatch_shared.a
intel-linux-media-patches-39163/README
intel-linux-media-patches-39163/libmfx-tracer.so
intel-linux-media-patches-39163/KMD-patches-for-realtime-threads/
intel-linux-media-patches-39163/KMD-patches-for-realtime-threads/0001-Work-around-to-avoid-reduce-spinning-in-the-userspac.patch
intel-linux-media-patches-39163/KMD-patches-for-realtime-threads/README
intel-linux-media-patches-39163/KMD-patches-for-realtime-threads/0001-Reducing-KMD-polling-on-ioctl-calls.patch
‘intel-linux-media-patches-39163/libdispatch_trace.a’ -> ‘/opt/intel/mediasdk/lib/lin_x64/’
cp: cannot create regular file ‘/opt/intel/mediasdk/lib/lin_x64/’: No such file or directory
‘intel-linux-media-patches-39163/libdispatch_shared.a’ -> ‘/opt/intel/mediasdk/lib/lin_x64/’
‘intel-linux-media-patches-39163/libmfx-tracer.so’ -> ‘/opt/intel/mediasdk/tools/tracer/’
cp: cannot create regular file ‘/opt/intel/mediasdk/tools/tracer/’: No such file or directory
+++ HotFixes installed, cleanup
Regard,
Ran
Jiandong_Z_Intel
Hi Ran,
First, great to know it works for you.
>> I guess I should not do any update, Right ?
I suggest you do update before install Intel Media Server Studio (MSS).  if you still want do update after install MSS, I think you should uninstall
with script "uninstall_sdk_UMD_CentOS.sh" first, then reinstall MSS.
>> Another question, is media sdk can run on windows host machine with guest machine running the same OS and kernel ?
As I know, the answer is NO, but if you use Linux host machine, maybe you can refer to How to setup Media Server Studio R6 on VT-d
>> I also have a laptop with i5-3210M, according to release notes only 4th and 5th Core are supported, so I can't use media sdk with that machine, Right ?
For Linux is yes, you can't use MSS on  i5-3210M. For Windows I think you can use Intel® Media SDK (https://software.intel.com/en-us/media-sdk), for details you can refer to "System Requirements" in Release Notes for Intel® Media SDK
Zachary
rshal2
New Contributor II
I have managed to solve that with rpm -Uhv
But on doing "yum update" I get the following error in CentOs 7.1:
---> Package perl-Carp-Clan.noarch 0:6.04-10.el7 will be installed
--> Finished Dependency Resolution
Error: Package: intel-linux-media-16.4.2.1-39163.el7.x86_64 (installed)
           Requires: libdrm = 2.4.56-39163.el7
           Removing: libdrm-2.4.56-39163.el7.x86_64 (installed)
           Updated By: libdrm-2.4.60-3.el7.x86_64 (base)
               libdrm = 2.4.60-3.el7
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
Ran
Jiandong_Z_Intel
Hi Ran,
I want to get more details,
Does the error in #2 is happened after you install UMD successful ?
Zachary
rshal2
New Contributor II
Jiandong Z. (Intel) wrote:
Hi Ran,
Zachary
Hi Zachary,
Yes, yum update does not work well after the installation in gold version.
I assume you can see it in your developmenet station too.
Anyway, I tried to run the samples but I get the following error:
[user@localhost release]$ ./sample_encode_drm h264 -i /home/user/mediasdk/sample_video/test_stream.yuv -o output.h264 –w 720 –h 480 –b 10000 –f 30 –u quality –d3d –hw
Encoding Sample Version 0.0.000.0000
ERROR: Unknown codec
Do you have any ideas what it means ?
Ran
Jiandong_Z_Intel
Hi Ran,
I want check if your graphic driver is okay in your system.
Can you send the output of following command line ?
$ cat /proc/cpuinfo | grep -i intel
$ lspci -nn | grep -i vga
$ ls -l /dev/dri
$ vainfo
$ uname -r
$ strace $ ./sample_encode_drm h264 -i /home/user/mediasdk/sample_video/test_stream.yuv -o output.h264 –w 720 –h 480 –b 10000 –f 30 –u quality –d3d –hw
Zachary
rshal2
New Contributor II
Hi Jaindong,
Thank you.
It works now, when I first tried the encoder I did copy-paste from the pdf to the shell. It turned out that it copies the "-" as another character, which resulted in demo parser confusion.
Now it works though "yum update" still gives error becuase of wrong dependency in the given rpm from Intel R6:
This is the information of my cpu:
[user@localhost mediasdk]$ cat /proc/cpuinfo | grep -i intel
vendor_id    : GenuineIntel
model name    : Intel(R) Core(TM) i7-5650U CPU @ 2.20GHz
[user@localhost mediasdk]$  lspci -nn | grep -i vga
00:02.0 VGA compatible controller [0300]: Intel Corporation Broadwell-U Integrated Graphics [8086:1626] (rev 09)
[user@localhost mediasdk]$ ls -l /dev/dri
total 0
crw-rw----+ 1 root video 226,   0 Jan  5 08:31 card0
crw-------. 1 root video 226,  64 Jan  5 08:31 controlD64
crw-rw----+ 1 root video 226, 128 Jan  5 08:31 renderD128
[user@localhost mediasdk]$ vainfo
libva info: VA-API version 0.35.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /opt/intel/mediasdk/lib64/iHD_drv_video.so
libva info: Found init function __vaDriverInit_0_32
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.35 (libva 1.3.1)
vainfo: Driver version: 16.4.2.1.39163-ubit
vainfo: Supported profile and entrypoints
      VAProfileNone                   :    VAEntrypointVideoProc
      VAProfileNone                   :    <unknown entrypoint>
      VAProfileMPEG2Simple            :    VAEntrypointEncSlice
      VAProfileMPEG2Simple            :    VAEntrypointVLD
      VAProfileMPEG2Main              :    VAEntrypointEncSlice
      VAProfileMPEG2Main              :    VAEntrypointVLD
      VAProfileH264Baseline           :    VAEntrypointEncSlice
      VAProfileH264Baseline           :    <unknown entrypoint>
      VAProfileH264Main               :    VAEntrypointVLD
      VAProfileH264Main               :    VAEntrypointEncSlice
      VAProfileH264Main               :    <unknown entrypoint>
      VAProfileH264High               :    VAEntrypointVLD
      VAProfileH264High               :    VAEntrypointEncSlice
      VAProfileH264High               :    <unknown entrypoint>
      VAProfileVC1Simple              :    VAEntrypointVLD
      VAProfileVC1Main                :    VAEntrypointVLD
      VAProfileVC1Advanced            :    VAEntrypointVLD
      VAProfileJPEGBaseline           :    VAEntrypointVLD
      VAProfileJPEGBaseline           :    VAEntrypointEncPicture
      VAProfileH264ConstrainedBaseline:    VAEntrypointVLD
      VAProfileH264ConstrainedBaseline:    VAEntrypointEncSlice
      VAProfileH264ConstrainedBaseline:    <unknown entrypoint>
      VAProfileVP8Version0_3          :    VAEntrypointEncSlice
      VAProfileVP8Version0_3          :    VAEntrypointVLD
      VAProfileVP8Version0_3          :    <unknown entrypoint>
[user@localhost mediasdk]$ uname -r
3.10.0-229.1.2.39163.MSSr4.el7.centos.x86_64
Ran
Jiandong_Z_Intel
Hi Ran,
Zachary
rshal2
New Contributor II
Zachary,
Thank you very much!
Ran
rshal2
New Contributor II
Hi Zachary,
I've started using the media sdk samples. I noticed that there is also the tutorial zip, but it seems to be quite the same samples. Is there any  mahor differences between these two packages ?
Ran
Jiandong_Z_Intel
Hi Ran,
There is an article https://software.intel.com/en-us/articles/media-sdk-tutorials-for-client-and-server talked about tutorials.
To my understanding like below -
Tutorials: step-by-step through use case examples from simple to increasingly more complex usages, focus on the H.264 (AVC) video codec
MSDK samples: a little more complex than tutorials. support more codec, and it is good performance for run benchmark.
Both MSDK tutorials and MSDK samples are helpful for start to use MSDK.
Zachary
