3075 Discussions
intel media sdk20170701 sample decode with screen capture plu-in
QIYUAN__FENG
hey ,nice to meet to:
when i am testing the sample sample decode with screen capture plu-in :error belows:
sample_decode.exe h264-hw -p 22d62c07e672408fbb4cc20ed7a053e4 -scr:w 1500 -scr:h 700 -d3d11  -o output.yuv
sts=MFX_ERR_OINVALID_VIDEO_PARAM(-15),CDecodingPipeline::init,m_pmfxDEX->Init failed at pipeline_decode.cpp:447
sts=MFX_ERR_OINVALID_VIDEO_PARAM(-15),wmain,Pipeline.Init failed at sample_decode.cppL681
plugin_loader.h:199[INFO]MFXBaseUSER_Unload(session=0x000001c9c34A20),sts=0
how can i resolve this issue?
Ramashankar
New Contributor III
Hi Qiyuan,
Replace ‘h264’ with ‘capture’ in command line argument.
sample_decode.exe capture -hw -p 22d62c07e672408fbb4cc20ed7a053e4 -scr:w 1500 -scr:h 700 -d3d11  -o output.yuv
keiyuen__feng
First of all,i am glad to recive to reply,I have tried two Intel media SDK (Intel(R) _media_sdk_2016.0.2 and Intel(R) _media_sdk_2017.0.1)
First:
INTELMEDIASDK_WINSDK_PATH     C:\Program Files (x86)\Windows Kits\10
INTELMEDIASDKROOT                      C:\Program Files (x86)\IntelSWTools\Intel(R)_Media_SDK_2016.0.2
file: ..x64/Debug/
                          22d62c07e672408fbb4cc20ed7a053e4/mfxplugin64_screen_capture.dll
                          22d62c07e672408fbb4cc20ed7a053e4/plugin.cfg
                          54542616243341e693ae899942ce7355/mfxplugin_camera_pipe64.dll
                          54542616243341e693ae899942ce7355/plugin.cfg
                          lib/igfx_s3dcontrol.lib
                          lib/libmfx.lib
                          lib/libmfx_d.lib
                          lib/sample_common.lib
                          libmfxaudiosw64.dll
                          libmfxsw64.dll
                          sample_decode.exe
                          sample_decode.ilk
                          sample_decode.pdb
commondline :
sample_decode.exe capture -d3d11  -hw -f 25 -p 22d62c07e672408fbb4cc20ed7a053e4 -w 1920 -h 1080 -fourcc nv12  -o output.yuv
yes,work well:
decoding Sample Version 6.0
Decoding Started
Frame number:550 ,fps 4.920 ,fread_fps:0.000,fwrite_fps:5.388
  • MY QUESTION IS:one:Why the use of CPU is very high,how can i cut down the cpu?,two:  ,how can i get the 25 fps??
second:
INTELMEDIASDKROOT                               C:\Program Files (x86)\IntelSWTools\Intel(R)_Media_SDK_2017.0.1
x64/Debug/        22d62c07e672408fbb4cc20ed7a053e4/mfxplugin64_screen_capture.dll
                          lib/libmfx.lib
                          lib/libmfx_d.lib
                         libmfxaudiosw64.dll
                         libmfxsw64.dll
                         sample_decode.exe
commondline:sample_decode.exe capture -d3d11 -p 22d62c07e672408fbb4cc20ed7a053e4 -scr:w 1920 -scr:h 1080 -fourcc nv12
or:::sample_decode.exe capture -d3d11  -f 25 -p 22d62c07e672408fbb4cc20ed7a053e4 -w 1920 -h 1080 -fourcc nv12
Decoding Sample Version  8.0
Features:Press 1 to toggle fullscreen rending on/off
Why is this version going wrong?
Ramashankar
New Contributor III
Hi Qiyuan,
You are writing raw output frames in file (by using -o option) which causes high cpu usage as well as low frame rate too. Exclude -o option from your command line and you will observe better performance.
Secondly, screen capture part doesn't consider fps parameter provided in command line, its you who need to make call to DecodeFrameAsync() at interval as per required fps. But if you opt to render the capture frames then renderer will try to achieve the fps rate as provided in command line (use -r option for this).
Also, please refer the 'readme-decode.pdf' file for further information of all these parameters.
keiyuen__feng
I am very glad to receive your reply, I want to know how to use (https://software.intel.com/zh-cn/articles/intel-media-sdk-screen-capture//simple_screen_capture.zip), how to obtain the original data of desktop?
my commonline:(tutorial_screen_capture.exe -n 500 -w 1920 -h 1080 -enc -enc_codec 'avc' -enc_file test1.avc),always mfxsts==MFX_ERR_NONE,tutorial_screen_capture.cpp,line 692,why error??
Ramashankar wrote:
Hi Qiyuan,
