libva vaInitialize failed in new thread created by pthread_create
jerry_l_
hi,
    i'm using msdk for linux server 2013 , the os is ubuntu 12.04 lts ,and the samples are building and running ok.
    now, i write a h264 decoder for my mutithreading programm, the decoder will be initialized in a new thread, and when create hardware device (drm mod), i got this error:
libva info: VA-API version 0.34.0
libva info: va_getDriverName() returns 1
vaInitialize failed
 While, if the decoder is not created in new thread, it's inialized ok
is there any problem like this  ??
or give me some tips ,3ks!!
Jeffrey_M_Intel1
Do you also see this problem when running as root?
jerry_l_
yes,it's running as root,and the thread attribute is same as the main thread,
can different mfx sessions use one vaapidevice instance when sethandle ?if so i can initialize the hard device instance at the main thread,and then use it in all new threads
