sample_decode capture screen failed
derek_q_
I build sample_decode and use it for screen capturing, but failed. I have tried it by several commands
1) Try load capture plugin from guid
sample_decode.exe capture -hw -d3d -async 1 -scr:w 1920 -scr:h 1080 -p 22d62c07e672408fbb4cc20ed7a053e4
command ouput:
plugin_loader.h :166 [ERROR] Failed to load plugin from GUID, sts=-9: { 0x22, 0xd6, 0x2c, 0x07, 0xe6, 0x72, 0x40, 0x8f, 0xbb, 0x4c, 0xc2, 0x0e, 0xd7, 0xa0, 0x53, 0xe4 } (Unknown plugin)
Default plugin cannot be loaded (possibly you have to define plugin explicitly)
Return on error: error code -3, e:\devel\zy\wifidirect\mediasdk\samples\sample_decode\src\pipeline_decode.cpp   355
Return on error: error code 1,  e:\devel\zy\wifidirect\mediasdk\samples\sample_decode\src\sample_decode.cpp     636
2) Try load capture plugin from file
sample_decode.exe capture -hw -d3d -async 1 -scr:w 1920 -scr:h 1080 -path mfxplugin64_screen_capture.dll
command ouput:
plugin_loader.h :130 [ERROR] Failed to load plugin from GUID, sts=-1: { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 } (Unknown plugin)
3) Finally, I tried the built in capture plugin
pretending that stream is 30fps one
pretending that aspect ratio is 1:1
Return on error: error code -3, e:\devel\zy\wifidirect\mediasdk\samples\sample_decode\src\pipeline_decode.cpp   921
Return on error: error code -3, e:\devel\zy\wifidirect\mediasdk\samples\sample_decode\src\pipeline_decode.cpp   394
I use Media SDK 2016.02, and the driver version is 10.18.10.4358 for HD 4000.
Is it necessary to install Intel Media Server Studio?
Ramashankar
New Contributor III
Hi derek,
command ouput:
is you capture plugin folder [22d62c07e672408fbb4cc20ed7a053e4] placed at same path  where sample_decode.exe is placed? If not then it could be one probable cause.
~ Thanks,
Bjoern_B_Intel
Hi Derek,
As Ramashankar mentioned, you can copy the directory with the plugin to your location of the executable. This has proved working. In rare cases the path variable gets used. I am in contact with development team here to get the details on correct usage.
Thanks & Best,
Bjoern
