sample_decode won't decode h264 header
trustno1
Hello everybody,
I've recently started to work on a h264 streaming decoder and renderer. As I'm quite a beginner in those fields,I downloaded the Intel Media SDK code samples to figure out how it basically works. The sample_decode project seemed to be the perfect sample for me. However, when I try to use it, it keep looping infinitely in the InitMfxParams method found in pipeline_decode.cpp
After some debugging and investigations, I found out that the header decoding is failing.
On line 626, this always return MFX_ERR_MORE_DATA, which causes the endless loop.
  sts = m_pmfxDEC->DecodeHeader(&m_mfxBS, &m_mfxVideoParams);
I am using the following args : h264 -i s.mp4 -low_latency -r
With "s.mp4" being a h264 video file found here : http://www.h264info.com/clips.html
I am developing on Windows 10, VS2015. HD Graphics 530 with the latest drivers.
Do you have any idea of what's going wrong?
Mark_L_Intel1
The sample app of the Media SDK only parses the elementary stream format of the video, the mp4 file in your example is the container of  multiple streams. To get the ES, you can use ffmpeg to demux the input file.
Mark
