About the sample_multi_transcode code structure & frame
峰_王_
Hello I use Intel Media Samples 6.0.0.98947 which is used on windows. This demo is complex very much , I want to see the code structure, or the releation of different classes. Or some documents which can help me unstand this demo. I can see your turtial demo. And l also read the documents inclued Intel Media Samples 6.0.0.98947 Files. Thank you very much!
Harshdeep_B_Intel
Please update to latest media samples ver. 6.0.0.49 here: https://software.intel.com/en-us/media-client-solutions-support/code-samples. We have documented all the different classes and functions used in sample_multi_transcode in our mediaSDK manual.pdf in media-sdk/doc folder. We understand samples code structure is complex to understand and we in process to simplify this. Let me know if your have any questions.
峰_王_
峰_王_
Where is mediaSDK manual.pdf  which have documented all the different classes and functions used in sample_multi_transcode. My path  is as follows:
峰_王_
The picture can't send you , the comand line is as follow: Microsoft Windows [版本 6.1.7601] 版权所有 (c) 2009 Microsoft Corporation。保留所有权利。 C:\Users\wangfengyf3>cd E:\GPU_Software\intel windows Demo new\Intel Media Sampl es 6.0.0.49 C:\Users\wangfengyf3>E: E:\GPU_Software\intel windows Demo new\Intel Media Samples 6.0.0.49>cd .. E:\GPU_Software\intel windows Demo new>dir "Intel Media Samples 6.0.0.49" 驱动器 E 中的卷没有标签。 卷的序列号是 0009-6C4D E:\GPU_Software\intel windows Demo new\Intel Media Samples 6.0.0.49 的目录 2015/06/11 11:21 . 2015/06/11 11:21 .. 2015/06/11 11:20 deprecated 2015/04/28 20:18 145,691 Media Samples Guide.pdf 2015/06/11 11:20 ocl_media_sdk_interop 2015/06/11 11:20 ocl_motion_estimation 2015/06/11 11:20 ocl_motion_estimation_advanced 2015/02/12 17:52 47 redist.txt 2015/03/24 14:34 236,758 Sample EULA.rtf 2015/06/11 11:20 sample_camera 2015/06/11 11:20 sample_common 2015/06/11 11:20 sample_decode 2015/06/11 11:20 sample_decvpp 2015/06/11 11:20 sample_encode 2015/06/11 11:20 sample_h265_gaa 2015/06/11 11:20 sample_multi_transcode 2015/06/11 11:20 sample_plugins 2015/06/11 11:20 sample_vpp 2015/03/31 17:20 1,543 set_INTELMEDIASDK_WINSDK_PATH.bat 2014/11/12 18:31 44 site_license_materials.txt 2015/02/12 17:52 50 third_party_programs.txt 2015/06/11 11:20 _bin 6 个文件 384,133 字节 16 个目录 114,219,220,992 可用字节 E:\GPU_Software\intel windows Demo new>
Harshdeep_B_Intel
MediaSDK manual is available in the mediaSDK folder. MediaSDK installed directory path in: C:\Intel\<INDE><MSS>/media_sdk_6.0.0.xxx/doc/mediasdk-man.pdf.
峰_王_
Hi , Harsh Jain Thank you very much .
