3059 Discussions
Decoding video from a live stream using Intel Media SDK and Directshow
wadrwadr
Some weeks ago I builded a directshow graph based application to decode live video stream.
The video stream comes from a multicast IP, compressed with h264 and encapsulated in MPEG-TS packets under the UDP protocol.
Filters in graph were connected as I explain next:
Elecard Network Source Plus -> Elecard Push Demultiplexer -> Elecard H264 Video Decoder
Graph also works using the next h264 decoders:
- Microsoft DTV-DVD Video Decoder
- CoreAVC Video Decoder
Now my company decided to use Intel Media SDK Directshow filters to improve decoding performance on a multiprocessor system.
Problem is that I can't find a single way to build a similar graph as the mentioned above using the Intel Media SDK h264 decoder.
I tried to replace Elecard H264 Video Decoder with Intel Media SDK h264 decoder but filter connection with push multiplexer throws an error... ( pin negotiation fails ).
Fact is I couldn't connect Intel h264 decoder to any source network/push demuxer I know.
Someone could successfully decode live video streams with similar format as I described above using Intel h264 or mpeg-2 decoders with Directshow?
Do you know some network source/push demuxer filters compatibles with intel media sdk decoders?
Thanks in advance.
Walter.
gthomaz
I don't know wich format is available in your old filter. But Intel Media SDK supports NV12 color format on input pins.
The conversion RGB to NV12 or YUV/I420/etc to NV12 is not available. You need to build your own filter...
There's a lot of tips here in this forum.. please search for "NV12" here....
Thanks!!
wadrwadr
Hello Guilhermer thanks for reply.
Correct me if I'm wronkg but I'm triying to decode here, color format is the output not the input of a decoder.
My problem is when I try to connect the intel h264 decorder input pin to push demuxer video output pin, video is still encoded in this stage.
Some well know input formats of a common h264 decoder filter are vc1, h264, x264, VSSH, Maiconcept h.264, ArcSoft H.264.
I did some research and found that push demux filter exposes the next media types in the video output pin:
MEDIATYPE_Video 73646976-0000-0010-8000-00AA00389B71
MEDIASUBTYPE_H264 8D2D71CB-243F-45E3-B2D8-5FD7967EC09B
MEDIATYPE_MPEG2_PES e06d8020-db46-11cf-b4d1-00805f6cbbea
MEDIASUBTYPE_h264 34363268-0000-0010-8000-00AA00389B71
None of these types seems to negotiate a connection with intel h264 decoder input pin but works ok with the decoders i mentioned early.
Walter.
gthomaz
Hello Walter!
Pardon, I'm wrong. I read fast and didn't realize about "DECODER".
I'm not work with live stream, but I did a decoder(player) here for a simple test.
I connected the filters like this :
H264 Source (file async) -> Intel MP4 Splitter -> (video) Intel h264 Decoder -> NV12toRGB(my filter) ->V.Rend
-> (audio) AAC Decoder -> Audio Renderer
It helps you?
Pardon for my fist reply
wadrwadr
Hi Guilherme.
Yes I tried with MP4 splitter but no luck.
I found another thing:
I wrote a small piece of code to get the media types expossed by intel decoder output and input pins and for my surprise result was 0 no media types exposed at all.
Very strange... do I have to setup something from code before connect ?
Walter.
gthomaz
Hi again Walter,
Really strange...
I did any special configuration... only the declaration of H264Decoder using the respective GUID ("CCCE52FD-02CB-482C-AC81-1E55EF1D61EE").
I've a suggestion to you:
Could you install an application like GraphEdit and check the media types available for H264 decoder?
For me, H264 Decoder has:
Input Pin -> Major Type: MEDIATYPE_Video
Subtype: fourcc (34363248) H264
Output Pin -> Major Type: MEDIATYPE_Video
Subtype: fourcc (3231564e) NV12
(to check this, please go to Graph-> Insert Filters...-> DirectShow-> Intel*)
wadrwadr
Hello Guilherme.
I found the problem.
For some reason exists two h264 media subtypes GUIDs.
The one supported by Intel h264 decoder input pin and defined in uuids.h at windows sdk is:
// H.264 compressed video stream
// 34363248-0000-0010-8000-00AA00389B71 'H264' == MEDIASUBTYPE_H264
OUR_GUID_ENTRY(MEDIASUBTYPE_H264,
0x34363248, 0x0000, 0x0010, 0x80, 0x00, 0x00, 0xaa, 0x00, 0x38, 0x9b, 0x71)
But exists another h264 subtype which is not supported by the filter, I found it debugging the filter and searching at the web:
//{8D2D71CB-243F-45E3-B2D8-5FD7967EC09B}
static GUID MEDIASUBTYPE_h264= {0x8D2D71CB, 0x243F, 0x45E3, {0xB2, 0xD8, 0x5F, 0xD7, 0x96, 0x7E, 0xC0, 0x9B}};
To fix the problem I had to modify the method CheckInputType in filter source code to support the new subtype.
Here's the modification:
HRESULT CH264DecVideoFilter::CheckInputType(const CMediaType *mtIn)
MSDK_CHECK_POINTER(mtIn, E_POINTER);
if (MEDIASUBTYPE_H264 != *mtIn->Subtype() && MEDIASUBTYPE_h264 != *mtIn->Subtype())
return VFW_E_INVALIDMEDIATYPE;
return CDecVideoFilter::CheckInputType(mtIn);
I test it with graphedit and works like a charm.
Regards.
Walter.
gthomaz
Ok Walter!
I'm happy that you could solve your problem!!!
I have been working in C#, so I use my decoder in a different way. I didn't have this same problem..
But, anyway, graphedit help us always! lol
Good job!
Devora_B_Intel
Hi ,
I built a similar graph using graph-edit tool.
Elecard Network Source Plus -> Elecard Push Demultiplexer -> MPC video decoder ->
I tried to implement the same graph programmatically using C++ and DirectShow - no success.
1. I don't know how to set the properties of "Elecard Network Source Plus" (in graphedit I just right click on the filter).
2. I don't know how to create an output pin for the elecard Push demultiplexer - how do I know what are the right configuration for the AM_MEDIA_TYPE struct.
Do you know how to do it programmatically?
Thanks in advance,
Devora
Anthony_P_Intel
Hi Devora,
I believe your questions are specific to Elecard's components and their documentation would likely answer the specifics of their APIs and component properties.
-Tony
flobadobatwork
Quoting gthomaz
Thanks!!
Guilherme, I need to write an NV12 to RGB24 converter filter. I've looked for code samples / algorithms all over this forum but can't find any. Do you have a code snippet or algorithm to do this?
thanks.
