Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Does Intel Capture Secondary Monitor?
Mohammad_T_1
Hello
I am Capturing Monitor with Intel Media SDK 388, Primary Monitor captured fine.
I want to capture Secondary Monitor also. Is there any why of capturing secondary monitor or any setting which can do secondary monitor capture in Intel Media SDK?
Guide me if there any way of capturing secondary monitor.
Anna_B_Intel
Display selection can be used on systems with virtual displays only (without physical display connected).
Best wishes,
Anna
Anna_B_Intel
Hi Mohammad,
Secondary monitor capture is not supported by Media SDK.
Best wishes,
Anna
Mohammad_T_1
Hello Anna B.
Thanks for your reply.
I have gone through media sdk screen capture manual: https://software.intel.com/sites/default/files/managed/da/91/mediasdkscreencap-man.pdf
It has section which says: Screen capture with Display selection. According to this section secondary screen capture might be possible.
Kindly have a look at the manual, I have seen but not able to do so.
Guide me if i am wrong.
Anna_B_Intel
Best wishes,
Anna
