Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Install fail on CentOS 1511
farhad_i_
Dear Team
I install fresh version of CentOS 1511 and make yum update . After update  CentOS Linux release 7.4.1708 (Core)
/install/SDK2017Production16.5.2/CentOS/ install_sdk_CentOS.sh
--> Processing Dependency: ncurses-libs(x86-64) = 5.9-13.20130511.el7 for package: ncurses-devel-5.9-13.20130511.el7.x86_64
---> Package pciutils-devel.x86_64 0:3.5.1-1.el7 will be installed
--> Processing Dependency: pciutils = 3.5.1-1.el7 for package: pciutils-devel-3.5.1-1.el7.x86_64
---> Package python-devel.x86_64 0:2.7.5-48.el7 will be installed
--> Processing Dependency: python(x86-64) = 2.7.5-48.el7 for package: python-devel-2.7.5-48.el7.x86_64
--> Finished Dependency Resolution
Error: Package: audit-libs-devel-2.6.5-3.el7_3.1.x86_64 (mss_updates)
           Requires: audit-libs(x86-64) = 2.6.5-3.el7_3.1
           Installed: audit-libs-2.7.6-3.el7.x86_64 (@base/7)
               audit-libs(x86-64) = 2.7.6-3.el7
           Available: audit-libs-2.6.5-3.el7.x86_64 (mss_base)
           Available: audit-libs-2.6.5-3.el7_3.1.x86_64 (mss_updates)
Error: Package: libdb-devel-5.3.21-19.el7.x86_64 (mss_base)
           Requires: libdb(x86-64) = 5.3.21-19.el7
           Installed: libdb-5.3.21-20.el7.x86_64 (@base/7)
               libdb(x86-64) = 5.3.21-20.el7
           Available: libdb-5.3.21-19.el7.x86_64 (mss_base)
Error: Package: binutils-devel-2.25.1-22.base.el7.x86_64 (mss_base)
           Requires: binutils = 2.25.1-22.base.el7
           Installed: binutils-2.25.1-32.base.el7_4.1.x86_64 (@updates/7)
               binutils = 2.25.1-32.base.el7_4.1
           Available: binutils-2.25.1-22.base.el7.x86_64 (mss_base)
Error: Package: python-devel-2.7.5-48.el7.x86_64 (mss_base)
           Requires: python(x86-64) = 2.7.5-48.el7
           Installed: python-2.7.5-58.el7.x86_64 (@base/7)
               python(x86-64) = 2.7.5-58.el7
           Available: python-2.7.5-48.el7.x86_64 (mss_base)
Error: Package: pciutils-devel-3.5.1-1.el7.x86_64 (mss_base)
           Requires: pciutils = 3.5.1-1.el7
           Installed: pciutils-3.5.1-2.el7.x86_64 (@base/7)
               pciutils = 3.5.1-2.el7
           Available: pciutils-3.5.1-1.el7.x86_64 (mss_base)
Error: Package: ncurses-devel-5.9-13.20130511.el7.x86_64 (mss_base)
           Requires: ncurses-libs(x86-64) = 5.9-13.20130511.el7
           Installed: ncurses-libs-5.9-14.20130511.el7_4.x86_64 (@updates/7)
               ncurses-libs(x86-64) = 5.9-14.20130511.el7_4
           Available: ncurses-libs-5.9-13.20130511.el7.x86_64 (mss_base)
Error: Package: elfutils-devel-0.166-2.el7.x86_64 (mss_base)
           Requires: elfutils-libs(x86-64) = 0.166-2.el7
           Installed: elfutils-libs-0.168-8.el7.x86_64 (@base/7)
               elfutils-libs(x86-64) = 0.168-8.el7
           Available: elfutils-libs-0.166-2.el7.x86_64 (mss_base)
Error: Package: elfutils-libelf-devel-0.166-2.el7.x86_64 (mss_base)
           Requires: elfutils-libelf(x86-64) = 0.166-2.el7
           Installed: elfutils-libelf-0.168-8.el7.x86_64 (@base/7)
               elfutils-libelf(x86-64) = 0.168-8.el7
           Available: elfutils-libelf-0.166-2.el7.x86_64 (mss_base)
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
Any solution how to fix ?
PS: half month ago the installation procdedure work fine for me but release after update 1511 was CentOS Linux release 7.3.1611 (Core)
Jiandong_Z_Intel
Hi There,
I think you check Getting Started Guide - Linux* Installation for your installation.
Zachary
