i am using IntelMediaStudio with CentOS 7.2 1511, but metrics monitor does not work.
[root@localhost sample]# ./run.sh
ERROR: Failed to subscribe for metrics, error code 1
BR
Gabriel
Hi
the same for me on Iris pro 580, E3-1585v5, system Supermicro X11SSV-M4F
# ./run.sh
What could be wrong?
MIndaugas
Same problem with 1585 v5 CPU:
root@node35:/opt/intel/mediasdk/tools/metrics_monitor/sample# ./run.sh
root@node35:/home/rasko# ./sys_analyzer_linux.py -v
Hardware readiness checks:
[ OK ] Processor name: Intel(R) Xeon(R) CPU E3-1585 v5 @ 3.50GHz
[ INFO ] Intel Processor
[ INFO ] Processor brand: Xeon
[ INFO ] Processor arch: Skylake
OS readiness checks:
[ INFO ] GPU PCI id : 193A
[ INFO ] GPU description: SKL SRV GT4
[ OK ] GPU visible to OS
[ INFO ] no nomodeset in GRUB cmdline (good)
[ INFO ] Linux distro : debian 8.7
[ INFO ] Linux kernel : 4.4.0
[ INFO ] glibc version : 2.19
[ INFO ] gcc version : 4.9.2 (>=4.8.2 suggested)
[ INFO ] /dev/dri/card0 : YES
[ INFO ] /dev/dri/renderD128 : YES
Intel(R) Media Server Studio Install:
[ OK ] user in video group
[ OK ] libva.so.1 found
[ INFO ] Intel iHD used by libva
[ OK ] vainfo reports valid codec entry points
[ INFO ] i915 driver in use by Intel video adapter
[ OK ] /dev/dri/renderD128 connects to Intel i915
Media SDK Plugins available:
(for more info see /opt/intel/mediasdk/plugins/plugins.cfg)
H264LA Encoder = 588f1185d47b42968dea377bb5d0dcb4
VP8 Decoder = f622394d8d87452f878c51f2fc9b4131
HEVC Decoder = 33a61c0b4c27454ca8d85dde757c6f8e
HEVC Encoder = 6fadc791a0c2eb479ab6dcd5ea9da347
Component Smoke Tests:
[ OK ] Media SDK HW API level:1.19
[ OK ] Media SDK SW API level:1.19
[ OK ] OpenCL check:platform:Intel(R) OpenCL GPU OK CPU FAIL
root@node35:/opt/intel/mediasdk/tools/metrics_monitor/sample# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 94
model name : Intel(R) Xeon(R) CPU E3-1585 v5 @ 3.50GHz
stepping : 3
microcode : 0xa6
cpu MHz : 1000.097
cache size : 8192 KB
physical id : 0
siblings : 8
core id : 0
cpu cores : 4
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch ida arat epb pln pts dtherm hwp hwp_notify hwp_act_window hwp_epp intel_pt tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt xsaveopt xsavec xgetbv1
bugs :
bogomips : 7008.62
clflush size : 64
cache_alignment : 64
address sizes : 39 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 94
stepping : 3
microcode : 0xa6
cpu MHz : 1000.097
physical id : 0
siblings : 8
core id : 1
cpu cores : 4
apicid : 2
initial apicid : 2
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs :
bogomips : 7008.62
clflush size : 64
power management:
processor : 2
cpu family : 6
model : 94
stepping : 3
microcode : 0xa6
cpu MHz : 1000.097
physical id : 0
siblings : 8
core id : 2
cpu cores : 4
apicid : 4
initial apicid : 4
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs :
bogomips : 7008.62
clflush size : 64
power management:
processor : 3
cpu family : 6
model : 94
stepping : 3
microcode : 0xa6
cpu MHz : 999.960
physical id : 0
siblings : 8
core id : 3
cpu cores : 4
apicid : 6
initial apicid : 6
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs :
bogomips : 7008.62
clflush size : 64
power management:
processor : 4
cpu family : 6
model : 94
stepping : 3
microcode : 0xa6
cpu MHz : 999.960
physical id : 0
siblings : 8
core id : 0
cpu cores : 4
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs :
bogomips : 7008.62
clflush size : 64
power management:
processor : 5
cpu family : 6
model : 94
stepping : 3
microcode : 0xa6
cpu MHz : 999.960
physical id : 0
siblings : 8
core id : 1
cpu cores : 4
apicid : 3
initial apicid : 3
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs :
bogomips : 7008.62
clflush size : 64
power management:
processor : 6
cpu family : 6
model : 94
stepping : 3
microcode : 0xa6
cpu MHz : 1000.234
physical id : 0
siblings : 8
core id : 2
cpu cores : 4
apicid : 5
initial apicid : 5
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs :
bogomips : 7008.62
clflush size : 64
power management:
processor : 7
cpu family : 6
model : 94
stepping : 3
microcode : 0xa6
cpu MHz : 1000.097
physical id : 0
siblings : 8
core id : 3
cpu cores : 4
apicid : 7
initial apicid : 7
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bugs :
bogomips : 7008.62
clflush size : 64
power management:
Can someone from Intel give some suggestions :)?
installed intel media studio: 2017R2
[root@transcoder2 sample]# ./run.sh
[root@transcoder2 sample]# uname -a
Linux transcoder2 3.10.0-327.el7.x86_64 #1 SMP Thu Nov 19 22:10:57 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
[root@transcoder2 sample]# rpm --query centos-release
centos-release-7-2.1511.el7.centos.2.10.x86_64
[root@transcoder2 ~]# ./sys_analyzer_linux.py -v
[ INFO ] Linux distro : CentOS Linux 7.2.1511
[ INFO ] Linux kernel : 3.10.0-327.el7.x86_64
[ INFO ] glibc version : 2.17
[ INFO ] gcc version : 4.8.5-11) (>=4.8.2 suggested)
[ OK ] user is root
[ OK ] Media SDK HW API level:1.21
[ OK ] Media SDK SW API level:1.21
[ OK ] OpenCL check:platform:Intel(R) OpenCL GPU OK CPU OK
[root@transcoder2 sample]# cat /proc/cpuinfo
processor : 0
cpu family : 6
model : 94
stepping : 3
microcode : 0xa6
cpu MHz : 800.000
physical id : 0
siblings : 8
core id : 0
cpu cores : 4
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch ida arat epb pln pts dtherm hwp hwp_noitfy hwp_act_window hwp_epp tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm mpx rdseed adx smap clflushopt xsaveopt xsavec xgetbv1 xsaves
bogomips : 7004.87
clflush size : 64
power management:
processor : 1
cpu family : 6
model : 94
stepping : 3
microcode : 0xa6
cpu MHz : 1000.000
physical id : 0
siblings : 8
core id : 1
cpu cores : 4
apicid : 2
initial apicid : 2
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bogomips : 7004.87
clflush size : 64
power management:
processor : 2
cpu family : 6
model : 94
stepping : 3
microcode : 0xa6
cpu MHz : 800.000
physical id : 0
siblings : 8
core id : 2
cpu cores : 4
apicid : 4
initial apicid : 4
fpu : yes
fpu_exception : yes
cpuid level : 22
wp : yes
bogomips : 7004.87
clflush size : 64
power management:
