Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Interlaced HEVC sample
BMart1
New Contributor II
Is there a sample doing interlaced hevc encoding? I've seen the whitepaper.
BMart1
New Contributor II
I'm trying to make hevc interlaced encoding work based on mediasdk_hevc_interlace_whitepaper.pdf and I think I found a bug. MFXVideoENCODE_Query turns MFX_PICSTRUCT_FIELD_SINGLE into MFX_PICSTRUCT_PROGRESSIVE:
mfxVersion ver = { { 0, 1 } };
MFXVideoSession session;
if (session.Init(MFX_IMPL_HARDWARE_ANY, &ver) != MFX_ERR_NONE)
    abort();
if (MFXVideoUSER_Load(session, &MFX_PLUGINID_HEVCE_HW, 1) != MFX_ERR_NONE)
    abort();
MFXVideoENCODE mfxENC(session);
mfxVideoParam encParams{};
encParams.mfx.CodecId = MFX_CODEC_HEVC;
encParams.mfx.TargetKbps = 8000;
encParams.mfx.RateControlMethod = MFX_RATECONTROL_CBR;
encParams.mfx.FrameInfo.FrameRateExtN = 60;
encParams.mfx.FrameInfo.FrameRateExtD = 1;
encParams.mfx.FrameInfo.AspectRatioW = 1;
encParams.mfx.FrameInfo.AspectRatioH = 1;
encParams.mfx.FrameInfo.FourCC = MFX_FOURCC_NV12;
encParams.mfx.FrameInfo.ChromaFormat = MFX_CHROMAFORMAT_YUV420;
encParams.mfx.FrameInfo.PicStruct = MFX_PICSTRUCT_FIELD_SINGLE;
encParams.mfx.FrameInfo.Width = 1920;
encParams.mfx.FrameInfo.Height = 1088;
encParams.IOPattern = MFX_IOPATTERN_IN_SYSTEM_MEMORY;
printf("%d\n", encParams.mfx.FrameInfo.PicStruct);
if (mfxENC.Query(&encParams, &encParams) != MFX_WRN_INCOMPATIBLE_VIDEO_PARAM)
    abort();
Greg_R_Intel
I wanted to let you know Intel now has an SVT-HEVC website for developers. This page also contains a new SVT white paper and links to the Trello board to track development of the SVT-HEVC encoder core. You can see the page here. https://01.org/svt Thanks! Greg Rose
Dmitry_E_Intel
Hi Bruno,
In case of bitrate control (not CQP) mode, HEVC interlace encode can only with SW BRC. From the whitepaper:
Only three bitrate control algorithms are supported MFX_RATECONTROL_CQP, MFX_RATECONTROL_VBR
and MFX_RATECONTROL_CBR. MFX_RATECONTROL_VBR and MFX_RATECONTROL_CBR are software
based bit-rate controls. To enable them use mfxExtCodingOption2::ExtBRC=MFX_CODINGOPTION_ON flag
without mfxExtBRC extended buffer.
Dmitry
BMart1
New Contributor II
Hi Dmitry,
What does it mean that CBR is software based? What's the downside?
Bruno
Dmitry_E_Intel
Hi Bruno,
It means and QP decision is done by C++ code inside MediaSDK :
https://github.com/Intel-Media-SDK/MediaSDK/blob/master/_studio/mfx_lib/shared/src/mfx_brc_common.cpp
not by code executed by GPU (as it works for regular BRC mode).
Dmitry
BMart1
New Contributor II
Will it limit the performance?
Dmitry_E_Intel
No, it doesn't affect performance.
