MFXClose fails to deallocate memory
David_C_15
 Hi all,
 I'm working on a project which uses multiple threads,
and each thread dynamically creates MFXVideoSession for decoding's purpose.
The problem is that whenever i try to Close() after a DisjoinSession() ,
Close() returns MFX_ERR_INVALID_HANDLE.
Eventually, memory leaks when the whole system is shutting down.
Does anyone have solution to this problem? or can give a reason why it happens?
I'll thank whomever gives it, in advance.
The version of meida sdk used is 2013 R2 by the way,
and here's my dev platform info.
OS: Win 7 (64bit)
CPU: i7-3770
Main Board : Asrock B75M
Mem :8 GB
Regards, David
andy4us
Don't call DisjoinSession() before calling close. As you found out that invalidates the handle. If you have multiple sessions, create a master session, have your sessions join to that, then on close, have the joined sessions call disjoinsession, and the master session, call close().
Petter_L_Intel
Also make sure you do not close the parent session until all child sessions are disjoined or closed.
Petter
David_C_15
Thank you all,  andy4us and Petter Larsson!
The advice really helped me out.
To add a bit, I think intel should provide a little more specific documentation on media sdk.
Regards, David
