Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
Out of memory errors encoding H265 4K video
Ike_S_
I am getting some random errors encoding 3840 x 2160 video using the HEVC encoder.
Sometimes it works, but many times I get a crash in mfxplugin32_hevce_sw.dll here:
144E1450  movdqa      xmm0,xmmword ptr [eax]
144E1454  movdqa      xmmword ptr [esi],xmm0  /* here, esi non-zero, but garbage */
144E1458  movdqa      xmm0,xmmword ptr [eax+10h]
144E145D  movdqa      xmmword ptr [esi+10h],xmm0
144E1462  movdqa      xmm0,xmmword ptr [eax+20h]
144E1467  movdqa      xmmword ptr [esi+20h],xmm0
144E146C  movdqa      xmm0,xmmword ptr [eax+30h]
144E1471  movdqa      xmmword ptr [esi+30h],xmm0
It looks to me that the plugin is trying to allocate an internal buffer into which the uncompressed data is copied. I believe the allocation fails, causing the destination pointer to become garbage. The destination buffer is not checked, so there is an access violation (caught with a try/catch) by the plugin, which causes pEncoder->m_mfxVideoSession.SyncOperation to fail with MFX_ERR_ABORTED (not a good error, by-the-way).
I am using this in a DirectShow encoder and at the time this exception is thrown, the memory allocated by GraphEdit is about 1.2GB. I am using v1.14.5.28 of mfxplugin32_hevce_sw.dll (release version), build 6/9/2014. Is there a newer version of the plugin that will solve this issue?
When it fails, it fails around frame 15-20. It seems that if it passes that point, it will continue until the end.
Harshdeep_B_Intel
Please check the encoding with one of our samples using sample_encode for H.265 4k video. As for as on  H.265 encoder, we did not come across any memory leak error. In regarding to DirectShow encoder, there has been no new support.
