i install MediaServerStudioEssentials2016 on CentOS 7.1.1503 but it not work:
# ls /dev/dri
ls: cannot access /dev/dri: No such file or directory
# cat /etc/redhat-release
CentOS Linux release 7.1.1503 (Core)
# rpm -qa | grep drm
libdrm-2.4.56-47109.el7.x86_64
drm-utils-2.4.56-47109.el7.x86_64
libdrm-devel-2.4.56-47109.el7.x86_64
# rpm -qa | grep libva
libva-1.67.0.pre1-47109.el7.x86_64
libva-devel-1.67.0.pre1-47109.el7.x86_64
libva-utils-1.67.0.pre1-47109.el7.x86_64
# rpm -qa | grep intel
intel-opencl-1.2-16.4-47109.el7.x86_64
intel-linux-media-16.4.4-47109.el7.x86_64
xorg-x11-drv-intel-2.99.917-8.20150615.el7.x86_64
intel-opencl-1.2-devel-16.4-47109.el7.x86_64
intel-linux-media-devel-16.4.4-47109.el7.x86_64
# uname -a
Linux localhost.localdomain 3.10.0-229.1.2.47109.MSSr1.el7.centos.x86_64 #1 SMP Tue Apr 19 09:40:11 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
# lspci -nn -v -s 00:02.0
00:02.0 Display controller [0380]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller [8086:0412] (rev 06)
Subsystem: ASUSTeK Computer Inc. Device [1043:8534]
Flags: bus master, fast devsel, latency 0, IRQ 11
Memory at f7400000 (64-bit, non-prefetchable) [size=4M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Capabilities: [90] MSI: Enable- Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [a4] PCI Advanced Features
Hi There,
I want to better understand your system. can you share following output of command line to me ?
$ cat /proc/cpuinfo | grep -i intel
$ lspci -nn | grep VGA
$ lspci -k -s 00:02.0
And, Have you met any error during run the script (install_sdk_UMD_CentOS.sh and build_kernel_rpm_CentOS.sh) ?
Zachary
# cat /proc/cpuinfo | grep -i intel
vendor_id : GenuineIntel
model name : Intel(R) Core(TM) i5-4460 CPU @ 3.20GHz
# lspci -nn | grep VGA
00:02.0 VGA compatible controller [0300]: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller [8086:0412] (rev 06)
# lspci -k -s 00:02.0
00:02.0 VGA compatible controller: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller (rev 06)
Subsystem: ASUSTeK Computer Inc. Device 8534
No error during run the scripts.
Hi Ildar.
Check i915 module with following command:
$ lsmod | grep i915
If the module is not loaded, try to load it manually:
$ modprobe i915
Hi Alexander.
i915 module loaded
$ lsmod | grep i915
i915 938476 0
i2c_algo_bit 13413 1 i915
drm_kms_helper 98274 1 i915
drm 311336 2 i915,drm_kms_helper
i2c_core 40325 5 drm,i915,i2c_i801,drm_kms_helper,i2c_algo_bit
video 19263 1 i915
no error in scripts, except need addition installation mesa-dri-drivers and net-tools
Hi Ildar.
on my machine will got following output.
lmsdk@jiandon-desk1:~$ lspci -k -s 00:02.0
00:02.0 VGA compatible controller: Intel Corporation Device 0d22 (rev 08)
Subsystem: Gigabyte Technology Co., Ltd Device d000
Kernel driver in use: i915
It looks like your i915 module is not load correctly.
let's check grub menu, please share the output of following command line.
$ cat /proc/cmdline
and let me know if you used UEFI in BIOS ?
Zach
Thanks. nomodeset in cmdline disable quicksync.
It looks like you have found the root cause of this issue, I am closing this thread.
Zachary
