Sync loss between 2 VPP components
Pavel_P_1
I'm trying to make composition with video and ARGB picture on 2017r2 and have the problem.
This problem was described in other topic
https://software.intel.com/en-us/forums/intel-media-sdk/topic/562583
but there is no answer.
My target sheme of execution is:
(session 1: [decoder]) ---> (session 2: [VPP]) ---> (session 3: [composite VPP] ---> [encoder])
        (ARGB surface) ---^
I use separate session for [VPP] because there can be multiple variants of resolution and frame rate at the same time.
The result of encoding has the next glitches: flipping forward and back between frames.
I made some experiments with different variants of execution scheme (of course all session are connected), and here are the results:
scheme A (works fine):
(session 1: [decoder]) ---> (session 2: [composite VPP] ---> [encoder])
                                           (ARGB surface) ---^
scheme B (works fine):
(session 1: [decoder]) ---> (session 2: [composite VPP]) ---> (session 3: [encoder])
                                            (ARGB surface) ---^
scheme C (works fine):
(session 1: [decoder]) ---> (session 2: [composite VPP]) ---> (session 3: [VPP] ---> [encoder])
                                            (ARGB surface) ---^
scheme D (works with glitches):
(session 1: [decoder]) ---> (session 2: [composite VPP]) ---> (session 3: [VPP]) ---> (session 4: [encoder])
                                            (ARGB surface) ---^
scheme E (works with glitches):
(session 1: [decoder] ---> [VPP]) ---> (session 2: [composite VPP] ---> [encoder])
                                                            (ARGB surface) ---^
All the next experiments I made are only with scheme E.
Video - timer, picture - png with dices.
Firstly, I added 250 surfaces to frame pool of [VPP]. Additionally I numbered empty surfaces using vertical light lines (number of light lines is the index of the surface) and received the following result:
https://www.youtube.com/watch?v=Wpuhqh-E_F0
It shows me that [composite VPP] uses surfaces that were taken from [VPP] but not filled with data yet. I.e. [composite VPP] can draw surfaces i and i-1 while [VPP] fills only surface i-1, and i-th is empty (or old).
So I added MFXVideoCORE_SyncOperation() in [VPP] and the glitches are gone. Because it's a rather slow solution, I'm searching for an alternative approach. I changed the direction of drawing surfaces (first - ARGB picture, second - frame from [VPP]) and glitches were gone again (without MFXVideoCORE_SyncOperation()). Next I made the following scheme: I draw the video frame, then ARGB picture, and third - invisible video frame from [VPP] again, and there were no glitches too (without MFXVideoCORE_SyncOperation()). But it's a slow solution too.
Right now i use frame buffer between (VPP) and (composite VPP) nodes. It's a queue with length = sync depth + 1. It solves the problem, but i think, we must find and fix the real error.
What else can I do to find a correct solution of my problem?
Dmitry_E_Intel
Hello Pavel,
Do you join the sessions by JoinSession() call?
Dmitry
Pavel_P_1
Hello Dmitry.
Yes, i made connection between sessions by MFXJoinSession() function for all schemes, i tested.
Pavel.
Dmitry_E_Intel
Did it help?
Pavel_P_1
No, it gives no result. The glitches are still here. And in my previous comment, I tried to say, that I used MFX Join Session() in my schemes from the beginning.
Dmitry_E_Intel
Is it possible to share a reproducer?
Molinder__Herman
I've encountered this issue as well. I'm using "scheme E" as Pavel P describes it, with one exception. I'm rendering the [composite VPP] output directly to HDMI, thus no encoding.
Any updates on this issue? Any suggested work arounds?
BR
Herman
