Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
3088 Discussions
advice on sample_encode program tuning for fast encoding speed
yu__leon
Hi there
I am using media SDK 1.26 and its sample_encode program to do a real-time H.264 streaming application.  I would like to ask for some general advice on how to tune the encoding parameters for fast encoding speed.
I am encoding at 1280x720 and 1920x1080, using software encoder; the typical frame rate of my application is about 10~15 fps.
I have selected  MFX_TARGETUSAGE_BEST_SPEED and the input format for encoder is NV12.   What other configuration parameters can I look at to improve the encoding speed?  any suggestion is much appreciated. thank you.
Ramashankar
New Contributor III
Hi Yu,
Some basic things to achieve fast encoding:
1. set AsyncDepth to 1.
2. Avoid B frame encoding, use h264 baseline profile. B frame can cause additional latency of 1-2 frames in encoding.
3. Provide one complete frames in input to encoder in each call.
4. Set TargetUsage to MFX_TARGETUSAGE_BEST_SPEED in encoder param.
5. Though software encoding is also suffice to produce 1 h264 stream @15 fps, but if you can exploit hardware capability then it may slightly speed up. Of course hw encoding have its own pros n cons. So need to take decision as per your working scenario.
Artem_S_Intel
If it is SW, the best way is to enable  multi-slice, it'll make encoder to run multiple slices in parallel.
yu__leon
Ramashankar wrote:
Hi Yu,
thank you
yu__leon
is this related to mfxInfoMFX.NumSlice setting?  or a group of parameters needs to be considered together?
Mark_L_Intel1
Hi Leon,
Ramashankar and Artem has very good advices and they are all correct, just try to summarize the general guide lines:
1. Choose HW mode instead of SW, Ramashankar's suggestions are based on HW mode.
2. SW mode works as a fallback if HW mode is not available because it is slower than HW mode.
3. In HW mode, you can use graphic memory as the internal buffer to save the time of copying, especially when you have multiple component(encoder, decoder, vpp) in the pipeline, this will speed up the processing speed.
4. Different use case could have different arguments to speed up. MSDK is designed to process multiple stream at the same time, it would be more efficient to to them in parallel.
Mark
