found and fixed buffer bugs in new Media SDK 2021r1
diablodale
Hello. The Media SDK 2021r1 SDK released this week has a few buffer under/overrun bugs in it. These bugs are also present in 2020r1.
Patch attached.
Such buffer bugs are often used for security violations. The bugs are all in one file `mfx_driver_store_loader.cpp` which is part of the dispatcher.
* Objbase.h needs to be included to access the api StringFromGUID2()
* last param on StringFromGUID2() is characters *not* bytes. Therefore it needs to be bufferbytes/sizeofbufferentity. This is done correctly in other files of the SDK.
*  RegQueryValueExW() does not guarantee null termination. See official Microsoft api docs. Therefore, it is unsafe to call wcslen(). The fix I used is to call RegGetValueW() instead. An alternative would be to use your SDK's custom WinRegKey class.
* it is unsafe to call wcscat_s() with a hardcoded char size because the size of that path is determined instead by the current function's parameters. Therefore, argument to wcscat_s() needs to be calculated using those parameters.
I've fixed the bugs locally so no rush for me. Instead for all your other customers.
Cheers
--Dale Phurrough
Gopika_Intel
Thank you for reporting and sharing your observations. We have informed the concerned team about this.
Gopika
Mark_L_Intel1
Hi Dale,
Thanks so much for the patch to fix our issue, I am really apologized for the late response, somehow this was ignored unintentionally.
I have submitted the patch to dev team and I will keep you updated.
Mark
AthiraM_Intel
The issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
diablodale
And where is the fix/resolution? From where can it be downloaded?
