Media (Intel® Video Processing Library, Intel Media SDK)
The Intel Media SDK project is no longer active. For continued support and access to new features, Intel Media SDK users are encouraged to read the transition guide on upgrading from Intel® Media SDK to Intel® Video Processing Library (VPL), and to move to VPL as soon as possible.
For more information, see the VPL website.
memory leak on CentOS for video transcoding sample
jie_y_
We found memory leak when using Intel® Media Server Studio 2017 R2 for Linux on Intel(R) Xeon(R) CPU E3-1515M v5 @ 2.80GHz
CentOS Linux release 7.2.1511 (Core)
00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:193d] (rev 09)
vainfo: VA-API version: 0.99 (libva 1.67.0.pre1)
vainfo: Driver version: 16.5.55964-ubit
we use Video Processing (VPP) Sample sample_vpp to transcode 40 streams and there is memory leak ~384k/min.
Jason
Max_M_3
Hi, can yu share what input parameters you were transcoding from and to which output? Thanks!
Dmitry_E_Intel
Hi Jason,
Please post a command line to reproduce the issue.
Dmitry
Mark_L_Intel1
Hi Jason,
As Max and Dmitry asked, could you share your command line and the method how you detect the memory leak?
Mark
jie_y_
Hi all,
  Sorry. We need more tests to verify it because after several hours the memory usage increased from 1.51G to 2.71G​ and stop increasing.
We changed the source code. We added a loop.
Jason
