Hi all,
I'm using a endoder/decoder and when the allocator is going to perform the memory allocation
status = mfxAllocator.Alloc(mfxAllocator.pthis, &_encRequest, &mfxEncResponse);
it returns MFX_ERR_MEMORY_ALLOC.
I'm using video memory in hardware mode.
In the decoder part there is no problem I have this problem only in the encoder. is there any reason for that errror? I think that there is enough memory.
Hi Fernando,
The information in your thread is not enough to understand why you are seeing the error. Can you let us know the following:
- Platform details (OS, hardware, version of MSS. If Windows, can you print output of system analyzer found in <SDK>/tools/sys_analyzer)
- Can you use our tutorial application simple_3_encode_vmem or simple_3_encode_vmem_async (https://software.intel.com/en-us/intel-media-server-studio-support/training) to see if you observe the same issue? These are code examples that are doing video encode using video memory and HW implementation.
- Can you send the command-line you are using (what codec, params being given)?
Here is the information...
Yes, I have test that examples and they works, but the problem is that I'm creating several encoders/decoders. with decoders there are no problems, but with encoders if I create one it is OK but when I create a second one alloc returns the error.
Intel Media SDK System Analyzer (32 bit)
The following versions of Media SDK API are supported by platform/driver:
Version Target Supported Dec Enc
1.0 HW Yes X X
1.0 SW Yes X X
1.1 HW Yes X X
1.1 SW Yes X X
1.3 HW Yes X X
1.3 SW Yes X X
1.4 HW Yes X X
1.4 SW Yes X X
1.5 HW Yes X X
1.5 SW Yes X X
1.6 HW Yes X X
1.6 SW Yes X X
1.7 HW Yes X X
1.7 SW Yes X X
1.8 HW Yes X X
1.8 SW Yes X X
Graphics Devices:
Name Version State
Intel(R) HD Graphics Family 10.18.14.4170 Active
System info:
CPU: Intel(R) Core(TM) i7-4500U CPU @ 1.80GHz
OS: Microsoft Windows 8.1
Arch: 64 bits
Installed Media SDK packages (be patient...processing takes some time):
Intel« INDE Media SDK for Windows 6.0.0.308
Installed Media SDK DirectShow filters:
Installed Intel Media Foundation Transforms:
Intel« Hardware M-JPEG Decoder MFT : {00C69F81-0524-48C0-A353-4DD9D54F9A6E}
Intel« Hardware VP9 Sync Decoder MFT : {07AB4BD2-1979-4FCD-A697-DF9AD15B34FE}
Intel« Hardware VP9 Decoder MFT : {0C69E30B-A112-4A86-B496-35120CD745D5}
Intel« Hardware VP8 Sync Decoder MFT : {451E3CB7-2622-4BA5-8E1D-44B3C41D0924}
Intel« Hardware VP8 Decoder MFT : {6D856398-834E-4A89-8EE5-071BB3F58BE4}
Intel« Quick Sync Video H.264 Encoder MFT : {4BE8D3C0-0515-4A37-AD55-E4BAE19AF
471}
